Ol bird gets a new heart
Update.  Shop called my NEW old crank is screwed up.  Only 10 over bearings everything went together well, then went to put the timing chain on and the crank gear slips on and wiggles N has some deep grooves from the gear breaking. Asked if I have another crank.  Yes I did and ran it up there but I had it in plastic, but failed to oil it down.  It's rusty and not sure if 20 over will fix the prob.  Gear fits that one perfect.  Other scenario is welding N machining the 1st one.  Block is decked, cleaned and cyls done.  Had the crank in but it's out again now. Heads are done too, New seats installed, seals, decked, freeze plugs. He said I could have brought it home today until this prob.  Doesn't look good for Woodward.
  • Replies 276
  • Views 15.5k
  • Wedding was beautiful, Walked her up and the pastor asked, who gives her away.  I said I DO, If he brought the check.  Everybody froze, Said I have too much time N $ involved here to JUSTA give her aw
  • Just wanted to share this pic of our Mighty Mac.  It's not justa for license plates anymore.
  • Last Indian
    Last Indian
    Well you could always drive it with a gas bottle hung from an IV pole!
Man you really have been up against it buddy! Your misfortunes well soon change to blessings I pray! I know you want to make the Dream Cruze, but it’s better to get the bird right than rush it.
Yeah I agree👍
do it right not rush it . There always next year justA
and we may even be over for that one !!!
Disappointing for sure but I'll be FORCED to drive that OL GTO.  Whatta hardship huh?  Plus I can fit 2 more in the back seat.  Game is not over yet.  Was actually amazed I had a spare turbo crank.  Spare is only 10 over so I still have 10 to play with.  Wouldn't use anything over 20.  30 over bearings are too easy to spin.  Thankz Gary.
59 minutes ago, 64 kiwi boni said:
Yeah I agree👍
I got an open air "celebrity status" cruising machine:pop_corn:
So I got a call today after the shop closed.  He machined a new longer keyway into the crank.  Solved all probs.  Now, he needs the flywheel N harmonic balancer.  I had torn the engine down and retrieved the heads.  The rest is all still in the car!  So for the last 6 hrs I've been tearing down the car to get to the flywheel.  The V6 is externally balanced so make a quick run with rotating assembly together to make sure all 6 are harmonizing.   Ready to go in the AM.  I could get my motor back tomorrow night.  Hope the ARP bolt kit is there and the gasket set, Most important the head gaskets.   Even unbolted the block in the car.  Drop it back down on the ground N pull that boat anchor I have Advertised on Craigslist.⚓ :rofl:
So I was up there soon after they opened this mornin.  Dropped off the flywheel and harmonic balancer.  Here you can have this back it's cracked, this was the balancer off the engine I took in with the busted crank gear too. Had to come back home N dig through my V6 boxes to find another balancer, clean it up N take it back up.  They JUSTA have to run it on a lathe N check balance. I might have it back today.:dancingpontiac:
Nothing from the engine shop.  The auto repair did manage to look at my truck. (I had to haul home on a trailer from the cabin)  The transfer case is gone.  Have a feeling when they install the new one, that they will find probs with the DR side front wheel too.  This is gonna be major expensive.  The Bird motor is gonna be a big bill as well.  Never fails......  Again, there goes the GTO paint fund.
I don’t know for sure how, but I think there’s a guy who occupies a white house somewhere south of you that is responsible for all of it. But hey I here he’s passin out money like candy maybe he’ll pay for it. You can call it building back better.
Have you ever considered painting the GTO green? Tell him it’s part of the green energy plan!
All of that put aside, I feel for you buddy, Karma’s a bitch, but when it lands on the wrong guy; I call that JustA plain wrong!
For once in the last 2 yrs there's something I CAN'T blame on that senile SOB.  Justa my own damn luck.  Never Justa one thing it's always a list.
From experience they come in three's 🙄   best  you go check that bore pump justA  ... !!!
Damn it man, you justa can't catch a break!
:slap:   Started with the GTO NOT making the club dustoff show.  Move to the Sunbird motor then #3 my tranfer case on the truck.  So breaking the crank timing gear in half is unheard of.....how do you crack the harmonic balancer right down the keyway as well???   Justa sayin I need to take a pic of the balancer for the EPIC fail thread. 😟
Nothing from either shop today. I'm assuming he talked me into balance N blueprinted the block??  So I hand sanded my lil fingers off.  Driveshaft, sanded, primed N painted.  Made my exhaust out of galvanized pipe. (it was an option back then)  So once a year polish with steel wool and Mothers mag polish til chrome like shine.  Well that's how it used to roll.  Spent hours on one bank of the exhaust.  Gave up, Prime N painted both banks Hot paint silver and repainted black on exhaust tips, yellow stripe N inside tip and clearcoated.  Both exhaust manifolds Eastwood exhaust silver.  Sanded the trans down but need to buy enough Red for the block N trans. Still have the bellhousing to clean, prep N paint.  Need to clean up the engine compartment before it gets the new heart.  HAVE to figure out my hydraulic mess as that is mounted behind the Radiator N can only be worked on with the Rad out.  The 2 lines I have from my stash are the upper lines.  I broke a lower.  Sharing the bosses ride is getting really old.
what do you mean mate???
 i would expect for a blown motor you certainly would balance and blue print all internals ?
I meant,  he put me in another line to wait. All can think of, why he hasn't called.
image.png.eae7d78d0359be22ec6f9c04e84381ad.pngimage.png.56a6cd21a520c78deb1d6649cd83c496.pngimage.png.196ff1e9ea2191a39bb57b4636ae0a3c.pngimage.thumb.png.9512fbf34567a0ac0ee2920a00ab5548.pngimage.png.8c8c2ec032d6aab9c1a1b2da0464e83a.pngimage.thumb.png.6abe3fbeed17b3e0620192fbfedb56ef.pngimage.png.90f91de287c52870f2a370999dd46c3e.png
Good things come to those who wait. But why in the hell do they have to take so long!
yeah man! i hate waiting come on hurry up !:rofl:
Reminds me of white wall tires ordered 9 months ago!!! .......
 good things come to those who wait JustA !!! hahahahaha :rofl:..... 9 months latter !!!:rofl:
Oh Kiwi - now you are justa pounding salt into the man's broken heart......
I'm no DR  and have no Patience......  He's only had my block for 2 months!!!  Have not hassled him about it, BUT now I'm gettin mad.  Have jumped through every hoop he's put out there. Shocked him with new/old parts that I had.  Everything on my end, has been cleaned, sanded, painted, cleared N ready to go back together.  Want it for dream cruise, no excuses for not makin Sellars this fall.   FCK.... all that's missing is U lil V6.  Called the shop working on my truck yesterday.  Waiting on the used transfer case.  Asked them to throw my old one in the back of my truck when they get it.  We will justa junk it.  Yea, NO....I want the $800 electric switch that puts it in 4X4.  Todays mission is to find or order correct hydraulic hoses for my hood.  Wondering about having my Radiator hot tanked before that goes back in too.
Take a drive to over to NPD or your local hydraulic shop bud.
Hot tanking the rad is probably a good insurance step since the car has sat for so long.
Getting back to normal.  2 phone calls before 8:30 this AM.  Truck is ready, heading out to pick it up.  Engine shop sent my pistons to be coated??  We talked about this N thought it wasn't necessary.  He said week to 10 days, guess it's been a week today.
It's that time to renew my plates on all my cars.  Checked into what plate I could put my custom Justa's on and the Bridge with yellow sunset was my only choice with 7 characters.  Have had the Blue plates since the 80's. Time for a change!
hmm you know we like pictures around here aye!:rofl:
