Ol bird gets a new heart
14 minutes ago, Frosty said:
Since when did we start caring about doing the right things the right way?
4 sure..... It's gonna screw up anyway and you end up doing the same job multiple times anyway.  Made 1/2 lap around the yard and my tractor puked all over the yard with gas blasting in every direction from the carb.  Ran for vise grips N pinched off the line and the fuel line tears like paper. WTF? I have no 1/4in fuel line so push the tractor back to the shed and dig out my push mower. After going through that, filling with gas, top off the oil to get er to fire up. NOTHING,  pulled my guts off N never fired.  shoved it into the side yard N left it.  Pulled the front bowl off the Sunbird, nothing looks wrong with the NEW accelerator pump, put 2 screws in it and worked by hand N it works perfect. Again WTF?  Put it all back together fire up the fuel pump and its blasting from the rear bowl.  Pulled that off and notice the crossover tube between bowls is missing most of the tiny O ring gasket. Pulled the needle/seat and blew through that, still can't find the rest of the missing rubber,  Blew through the passage way in the bowl and found another small piece.  Still missing about half of the O ring. This is brand new out of the box gaskets from the rebuild kit.  AGAIN WTF?  Will stop on the way home from Vball and get new O rings,  can't put it back together til I find the missing rubber.  That'll plug the secondary needle valve in a hurry.  Didn't need yard lights, I was glowing so RED, it looked like sunset when I gave up and went in.:badGT:
  • Replies 276
  • Views 15.4k
  • Wedding was beautiful, Walked her up and the pastor asked, who gives her away.  I said I DO, If he brought the check.  Everybody froze, Said I have too much time N $ involved here to JUSTA give her aw
  • Just wanted to share this pic of our Mighty Mac.  It's not justa for license plates anymore.
  • Last Indian
    Last Indian
    Well you could always drive it with a gas bottle hung from an IV pole!
OK...Guess what 2 rubber O rings the diameter of a pencil cost????   That would be $10.06 and comes with it's own Holley pre packaged kit. This is NOT OK.
