I installed the drive shaft today, to see what modifications I needed to do to the floor …
It was a perfect fit, how ever the u bolts that Brett supplied where 6mm too short !
I will get into him tomorrow
I then spent the rest of the day opening up the tunnel , and completly forgot about taking pics !
So watch out for next weekend !!!!
  • Replies 308
  • Views 12.3k
I am of two mind about what to do about the shifter ! Option one is to use the ve Holden floor shifter and make a mount for it on the tunnel … keep in mind I am sticking with my factory bench seat …
Or …. Use the factory column shift and buy a cable kit to hook it to the 6l90e
The column way will look more factory and won’t be an issue with my factory bench seat … has anyone done a similar shifter ??????
NOPE....never messed with a Holden floor shifter. Sorry
My personal preference would be to do a column shift if you are keeping the front bench seat. A floor shifter and a bench seat can sometimes look like an awkward after thought. If you were going with bucket seats, the floor shifter would be fine, in my opinion
Besides with a column shifter you can have your boss next to you on date night or the grandkids when you go for ice cream.
Yup, what he said.
Ditto. Stick with the column shift.
HMMMMM ! very good points !!!cheers
Which is a better idea than the floor shift... next issue.... how do i do the manual mode ? Rick, did you hook up your 4l60 trans to a manual mode of some sort ?
How about Paddle shifters? Not sure if there is a ton of room for paddle shifters with a column shifter. Perhaps paddle shifter buttons on the inside rim of the steering wheel?
i will need to investigate cheers
