I installed the drive shaft today, to see what modifications I needed to do to the floor …
It was a perfect fit, how ever the u bolts that Brett supplied where 6mm too short !
I will get into him tomorrow
I then spent the rest of the day opening up the tunnel , and completly forgot about taking pics !
So watch out for next weekend !!!!
  • Replies 315
  • Views 13.2k
I am of two mind about what to do about the shifter ! Option one is to use the ve Holden floor shifter and make a mount for it on the tunnel … keep in mind I am sticking with my factory bench seat …
Or …. Use the factory column shift and buy a cable kit to hook it to the 6l90e
The column way will look more factory and won’t be an issue with my factory bench seat … has anyone done a similar shifter ??????
NOPE....never messed with a Holden floor shifter. Sorry
My personal preference would be to do a column shift if you are keeping the front bench seat. A floor shifter and a bench seat can sometimes look like an awkward after thought. If you were going with bucket seats, the floor shifter would be fine, in my opinion
Besides with a column shifter you can have your boss next to you on date night or the grandkids when you go for ice cream.
Ditto. Stick with the column shift.
HMMMMM ! very good points !!!cheers
Which is a better idea than the floor shift... next issue.... how do i do the manual mode ? Rick, did you hook up your 4l60 trans to a manual mode of some sort ?
How about Paddle shifters? Not sure if there is a ton of room for paddle shifters with a column shifter. Perhaps paddle shifter buttons on the inside rim of the steering wheel?
i will need to investigate cheers
Oh now that's thinkin with your dipstick....I like it!
A little bit more progress this weekend ,,,,,,
It reminds me of my GTO when I decided to drop a 4L80e into her. The original console would never fit afterwards so we had to fabricate one. If you plan on a keeping the bench seat, it'll be a lot easier.
Nice job!
yes i am keeping the bench seat Mick cheers
19 hours ago, JUSTA6 said:
Nice job!
i am so enjoying the sheet metal work ! its fun !
A little more progress this weekend
Making the replacement brace over the new floor pan section .
Nice looking work Kiwi!
