So where are the pictures already?
Geez don’t leave us hanging like that Kiwi!
  • Replies 278
  • Views 11.3k
I have to do my days work first frosty then head to main freight depot and pick them up !!!! After another 6 month wait and way too many dollars !!!!
Okay but you got us all worked up
Are you sitting down ? ........pop_corn
The disc brake conversion kit I bought in January has arrived !!!! Finally !!!!
I am very impressed with the quality of this kit ! i choose the disc/drum kit and i cant fault this whole kit !!! it has everyting i will need to assemble onto the stub axles !!! the brackets look nice and strong with good quality welds and the pcd is correct for my at 127mm !!!
this is a major step foward for the build !
big thank you to chris from auto city classics !!! i will be buying a gas tank next cheers
