Fitzy's GP is back!
very cool mix of cars Mate !!!
the hz grill looked bloody neat as !
the xb with the patina, looks nice too !, i have never seen a fe with a canopy !!!! bet thats rare as !
  • Replies 2.2k
  • Views 102.5k
You know...I might be a redneck. The pic looks like a hillbilly meth lab but it's actually my place with me changing everything's oils all at once - a successful & rewarding experience. A mechanic will charge quite a bit to do an oil change, they'll use inferior quality oil bought in bulk and the job will be handed to the apprentice who will drain the old oil and as it's still dripping out will replace the drain plug and get the car finished because he's under the pump. I warmed up each engine (with a drive) and each drain was at least an hour. I use quality synthetic oil only ever bought when it's on special, because I'm a tightarse.
Thanks for sharing Fitzy!
Nice shots mate. Thankz for sharing.
Here is the hoist. It's a UK made Bradbury and despite it's appearance is apparently a quality item. As you can see, it has chassis rails and ramps. I'm getting someone to inspect it soon. The sloping roof is made to slide away, so when I start servicing double decker buses, it won't be a problem.
The old fella was clearly thinking ! Doing a sliding roof works a treat !!!
And having it open like that, lets a lot more natural light around where your working !!!!
That’s the down side of my one , it’s so dark when you are working on it !
I have to have lights set up so I can see !!!!!
Plus, you're getting old...
Never !!!!!!
Here's something to consider - let's open up a can of worms and talk about oil. Opinions will rush in, tempers will fray and if a certain member chimes in, insults will be hurled. After I performed multiple oil changes last weekend I thought I'd try and get an oil that would cover all bases and buy it in bulk. I read about Shell Rotella, which is a diesel oil. Old flat tappet engines need zinc and diesel oil in addition to containing plenty of zinc is also a high detergent oil. Frequent oil changes are probably better overall than fretting over what oil to use. I reckon I could get away with using Rotella (or any quality diesel equivalent) in the GP and my ute but will use something else in the missus' Mazda and my mower. Having said that, someone on a forum (bobistheoilguy.com) said he has 23 engines at home and Rotella goes in the lot - everything from an aircooled Briggs to a Cat truck motor. Never had a problem.
Interesting.
The Ponti motor, although freshly rebuilt is a 60 year old thing, the ute is 36 years old, mower is 21 years old and Mazda is 14 years old, so I don't think I can hurt anything.
Another comment was that someone said (anecdotally) that a test was carried out where half of a truck fleet had 5000 mile oil changes whilst the other half had 25000 mile oil changes. Upon eventual 1 million mile teardown of all engines, hardly any difference in wear was noted - we're talking single digit thousandths of an inch. You can't believe everything you read of course, but an interesting thought.
Was the test on the truck fleet done with regular oil or synthetic?
i really dont think its wise to use one type of oil on all.
my brand new china van will not like oil i put in my ponti ! neither will my supercharged hemi in the cat !
my 1957 fergy tractor ... well that old girl just loves any old slippery stuff ! i could fill it with banana peals Despicable Me Monkey GIF by Boring Merch
But you should try it mate.... see what happens cheers
So "I should try it and see what happens."
How does an exploding oily mess from several sources sound?
None of my vehicles are anywhere near modern and I'd like to think I can't hurt anything. I suppose the other thing to consider is that oil weights are determined by the SAE, based in America of course. I live in a hot tropical zone and not the icy cold northern US. I reckon I could afford to go a little heavier to compensate. I don't need 0W oil to get started in winter. A 30 weight will be fine.
I'll be sure to take pics of the mechanical mayhem that is bound to ensue.
I can't recall. If you get bored, get on to bobistheoilguy's site and you can spend days there trawling through the endless oil related topics. I'm pretty sure we all overthink oil suitability. As long as it's decent quality and is changed before the Apocolypse it'll probably be okay.
