Identifying my motor
Hey guys. I have a 63 Lemans and was told it has the original motor. When I have tried to verify this using the stamps on the block they do not match any numbers for that year that I can find. Any ideas?
Mike
I have run into this with Chevelles. The motor could be original to the car but it could have been a warranty replacement engine 12/24 months after the the car was bought. Sometimes the casting numbers can be difficult to track.
Mike
Help us a little....what motor are you running in your Lemans? Is is a straight four, a Buick nail head, or a Pontiac V8? This will make a difference were to look for the VIN number on the engine.
It is a pontiac v8 supposed the be the 326 original to the car. I'm trying to verify this.
Look for the casting number on the block. A '63 326 V8 will be 548211. A '64 326 is 9773153. A '65 & 66 326 is 9778840. Casting codes from 1955 to 1963 are on the passenger side of the block. From 1964 to 1967, they are on the distributor pad (except for the 421). Casting codes for from March 1967 on are found on the rear of the block just behind the number 8 cylinder. This will confirm the original displacement of the engine and the year of the block was made. It will not confirm it is the original engine.
Now there should be a block code. It roughly corresponds to the body/transmission/carb/engine combination. So for a '63 A-body with a 326, the possible codes can be. These can be found on the front of the block below the passenger side head.
Code
Car
Year
CID
HP
Trans
RPO
VIN
Carb
Block Cast
Main
Notes
590
A-body
63
326
280
Powerglide
L-76
1x4
548211
2
HO
68X
A-body
63
326
250
3-speed
L-30
1x2
548211
2
600
A-body
63
326
260
Powerglide
L-30
1x2
548211
2
690
A-body
63
326
250
Powerglide
L-30
1x2
548211
2
70X
A-body
63
326
280
4-speed
L-76
1x4
548211
2
HO
71X
A-body
63
326
260
3-speed
L-30
1x2
548211
2
Date Code
The date code is cast on the distributor pad. It is a 3 or 4 digit code. The first digit will be a letter. A=January, B=Febuary, C=March, etc. Followed by a 1 or 2 digit number for the day of the month. The last digit will be the year.
The build date of the engine will be sooner than the build date of the car. If it is older than the build date of the car, the engine has been replaced (it is possible it a service replacement).
