Bringin' It Back From The Dead - 70 Catalina Convertible
Hello,
A little late but as promised, pictures of my radiator that leaks like a sieve, especially once it warms up. I should have known to not buy the least expensive radiator but it bit me twice buying this one twice. Dumb, yes, I know. "Buy once and cry once" as they say around here and I shoulda' listened. The Dexcool coolant has some radiator dye in it that I added that causes the color change to yellow on the absorbent mat.
I will soon be a thousand bucks plus tax and shipping poorer buying hopefully a better radiator.
  • Replies 393
  • Views 25k
    Hello, All good news. As of yesterday, it is insured on a State Farm "Agreed Value" policy and plated. She is street legal. There are many little things that still need to be done to it and of c
    Hello,    And the clear went on today.  Still need to paint the hood and the front / rear valance panels below each bumper.   Rick
    Hello,    And a drum roll please . . . the Large Zucchini On Wheels has done its time, paid its debt to society and has been paroled from paint jail.  I got it home on a flat bed earlier this eve
Hello,
Catching up a little. I have picked an aluminum Griffin LS swap radiator that will have a single large SPAL electric fan with a shroud. It is a two-row radiator with 1.25 inch tubing that is dimensionally almost the same as the failed Cold Case radiator. The radiator hoses will also not change.
This fan will run a pulse width modulation controller through the "YAZ" connector (SBL-YAZ-PT10-PKG) rather than the Davies-Craig analog controller that I have been using. There was certainly nothing wrong with the Davies-Craig controller - I simply wanted more precision in the control of the new SPAL fan. The already existing FlowKooler water pump body (part number 1669) will be drilled and tapped for the temperature probe in the YAZ connector.
This hardware is not here yet and I have some vacation time ahead of me so I don't know when it'll get installed. Fingers crossed that this is the absolute last radiator this car ever gets.
Hello,
I returned from vacation this past Monday and space has finally opened up today in the shop for the Catalina to get its new Griffin radiator, SPAL fan and the SBL-YAZ-PT10-PKG pulse width modulation fan controller.
Hopefully, this will be a one day job.
Hello,
It ultimately went in for the radiator replacement last Friday and was ready late yesterday but I picked it up today. And she's running very nicely with zero radiator leaks and very good engine temperatures. It was cool enough tonight that I put the top down.
If anybody ever needs the part numbers for what fits for an LS swap radiator with a single large Dewitts fan, here goes:
Griffin radiator 8-70008-LS
Dewitts DWR-32-SP480
Fingers crossed that I can keep this car running well for a while. It really needs a bath because it is very dusty.
3 hours ago, B52bombardier1 said:
Hello,
Best Wishes Good Luck GIF by Studios 2016
Hello,
I am back in the Detroit area as of last night on grandparent duty for a week. The Cat radiator is running well and has yet to top 210 degrees F. This new single fan is also quieter than the two older fans. And yea, no leaks.
Strangely, and some will remember this happening on old cars. My wife and I drove the Cat to church last Sunday for the first time. We come out and the horn is blowing random lengths of time very loudly. It was not a stuck horn button. I had to pull the power wire out of the center of horn relay to get it to stop.
This relay was / is only about 18 months old. Gotta' get a new one, I suppose.
Hello,
I got back home from Detroit on Wednesday night and drove the Catalina to work today with the top down. I'm off work early for the long weekend and I should be able to pick up my new horn relay later this afternoon that I mention immediately above. This should be an easy repair.
I stopped to eat a sandwich at a local restaurant on my way home today. As I was standing at the cash register to pay, a little girl maybe five years old and her in tow little brother approached me. With enormous confidence, reverence and a wide grin smile, she said "Mister, you have a very cool car".
I think her Dad may have encouraged this brief conversation but still, it made my day.
Hello,
It has been two good days of light wrenching and problem solving on the Catalina. More and more miles continue to be added to the odometer and I like to go back and look to see if things have loosened up. As we all know here, these are old vehicles that need a good inspection routine.
I tightened up the nuts and bolts on the new steering rag joint that got installed during the resto-mod. I also put the largest socket that I own onto a breaker bar to check the tightness on the Pitman arm nut. The drive shaft nuts also got a quick look. All of the other new steering components up front are protected by cotter pins.
You might recall that the original light as a feather road contact feel 1970 steering gear box got swapped out during the resto. It got replaced with a modern rebuilt GM Saginaw steering gear box out of a 1993-98 Jeep Grand Cherokee that has a much better steering ratio and a heftier hydraulic torsion bar valve. Yet, it still has the same sweep angle as the 1970 box - the car's turn radius is the same. All still tight here and no leaks anywhere.
I finally got around to putting the engine cover onto the 2002 model year GM truck LS engine. The intake manifold had lost its M6 x 1.0 nut that could hold the engine cover down and a little JB Weld on a new metric nut solved that problem.
And lastly, I finally pushed enough brain cells towards solving why the turn signals on this car blinked so slowly. A process of elimination led me to cleaning up a little corrosion on both sides of the 20-amp turn signal fuse holder contacts. Some Caig's DeOxit electronic contact cleaner, gentle scraping with a pick tool and a light bit of copper anti seize has now solved this problem. This is probably secondary to the years of convertible top water leakage that this car suffered that destroyed the driver's floor pan sheet metal.
Hello,
I continue to have doubts about my front brakes. They do stop the vehicle but on a hard pedal application, the front of the car develops a substantial vibration. I have taken the drums off and the shoes on the left front have small gouges in the friction material about half the size of a grain of rice. This friction material also produces a lot of dust. The drums were both turned when I put everything back together a year or so ago and there are no burn or scuff marks on the drum friction surface. The infrared temperature gun shows a temperature of typically 250-275 F after an average drive.
So I called up the tech support guy at the Fort Wayne, IN company that rebuilt the brake booster on this car - "Brake Materials and Parts". He suggests that the friction compound on these shoes is too soft for the usual temperatures that the front brakes on this car develops.
Last night, I placed a $38.00 order at my local O'Reilly's for a brand new set of 11 x 2.75 inch shoes for the front and they will be here on Tuesday. It does not matter what friction material is on these because my Indiana tech support guy say's send them to him as they are. He will remove whatever friction material is on them and replace it with something a little harder, that makes a little less dust and that can resist a 600 degree F temperature. He will also "arch" and contour these shoes for a more perfect and complete fit against the inside of the drums. I did not remember saving the old shoes when I took this car apart but sure enough, I did. However, the friction material on these is riveted, not bonded. I will need to call the Indiana shop back on Monday and ask if using a riveted style is suitable for his efforts.
I'm told this new friction material is not ceramic and not carbon fiber and certainly not asbestos. The service price for this is $36 per shoe with an additional one time $30.00 shop fee. Plus shipping. And about a 10-14 day turnaround time to do the work. If the first set of shoes works as well after this treatment as I hope, I will probably send in a second set for future use.
We shall see how things go when I get them back. If this does not work out, I will probably be in the market for a front disk conversion kit.
7 hours ago, B52bombardier1 said:
Hello,
Compare Cars
Nothing wrongway with your big arse drum front end Rick ! Both my 59 caddy and the 64 Bonnie have the same front drums and they stop really really well ! JustA don’t do it on a race track !!!! rofl
I do what you’re going to do and get the new shoes matched to your drums ! That’s important.
And your onto it
Change the composition 🙏🍺
Hello,
I had a very "dark" situation happen to me in the Catalina two nights ago. I'm returning from an evening car club related meeting with the headlights on and all is normal. I turn down my rural road and put on the high beams - all four headlights are now on about one mile from home. The heater blower has been on with the top down. Mind you, this was this car's longest night time trip so far since arising from entry into its 1993 dead slumber.
Seventy five yards from my driveway, I apply the brakes and a second later, everything dies. Total blackness in a totally dead car, no running engine on a rural road with the closest overhead street light three quarters of a mile away.
Its very dark and I manage to use these "Armstrong Motor" bicep muscle guns of mine to man handle the steering of my Catalina just barely into my driveway. And it coasts to a safe stop well clear of the street.
So, no electrical power. Not even a floor courtesy light with the door open. I head into the shop to get a flashlight and come back to pop open the hood. I had long ago removed the charred, melted and blown fusible link in this car's underhood engine electrical harness and replaced it with a fuse - a 25 amp fuse, in this case. That fusible link wire was toast the day I brought this car home on a trailer and I have a phobia against fusible link wires because they are impossible to repair on the roadside. Clearly, I undercounted how many amps this car might consume in situations like this evening drive and I over-protected that eight gauge wire with too small of a fuse.
In went a new thirty amp fuse and everything instantly came back to life. I started it up and promptly pulled it into its shop parking spot. I'm still debating myself whether a 30, 35 or a 40 amp fuse will be more suitable but I now have a glove box pill bottle full of various size fuses.
what circut was that on Rick ???
dont you have it all split down ? and on 30 amp to each section for those high drain ones like head lights hood horn heater fans(they are 60)
I am going to spilt everything on the 63 and take all the load off the ignition switch and light switch with 30 amp relays and 30 amp fuses on each, but what i dont know is what gauge wire to use, its all fine using higher amp fuses but it has to be the right gauge wire that your protecting !!!
i always remeber when i was a kid watching my dad pulling the fuse on the wall in the garage and puting in a fuse with a nail in it when he would want to weld !!!
i am sure he really never though about how hot the wires in the wall of the garage got hot while he was welding back then !!!! rofl
Hello Chris,
   You may recall that the 400 cubic inch engine was missing when I got this car and much of the under-hood wiring had been tampered with or was otherwise faulty.  In the pursuit of this resto-mod, I had to adapt things a bit along the way.
 I went with an eight-gauge wire to replace the burned-up length of fusible link wire in this car and protected the new wire with a fuse very near the battery where the new eight-gauge wire sources its power. I could never determine why the fusible link wire burned up.  Would a six-gauge wire have been a better choice? IDK. This LS engine car is running a 130-amp capable alternator and I’m nowhere near using that much amperage.
This new, 25-amp fuse protected, eight-gauge wire connected to the car under-hood harness at circuits “BZ” and “DW” on the attached picture.   BZ and DW are the main power input wires to car’s engine side of the fuse block and this feeds everything on the half of the fuse block directly above the driver’s feet.
There is also a dedicated heavy gauge orange wire from the battery (I can only presume originally from the battery - maybe the alternator??) to the fuse block for the convertible top hydraulic pump motor that is not mentioned in the attached picture here. This was one of several wiring mysteries that I encountered with putting this car back into service.  As far as I could tell, most of the length of that wire from the battery to the firewall had never had fuse protection but it is now protected by a 25-amp slow blow fuse close to the battery. The fuse panel also has a dedicated 40-amp self-resetting circuit breaker for this pump, power windows, power seats and power door locks at the top left corner of fuse panel. A 25-amp slow blow fuse only for the pump motor is plenty sufficient because this car does not have power seats or power windows, etc.
The new radiator fan, AC condenser fan, transmission cooler fan and the new heating and AC system from Old Air Products all get their power from new relay controlled and separately fuse protected circuits under the hood – sourced from the battery. Control / ignition key on power for these relays does come from the original car fuse block sources.
The original Pontiac / Harrison heat and air conditioning system was completely removed and no longer consumes power from the car’s fuse block. This means there is now a lot of extra amperage available on the car’s 30-amp “Heater A/C” fuse on the top of the right column of fuses and I have no idea what I will do with that capability. Probably nothing but all 30 amps are available there because this car has none of the letter’s A through J factory accessories that consumed power on that circuit – the factory never installed those.
The power for the headlights also arrives on this eight-gauge wire input to the fuse block.  I’ve hand touched all of the under-hood wires while the car was running its accessories to see if any wire was warm or hot. All wires were a normal temperature here.
  Nevertheless, it’s always a fine line between clever and stupid.  And I crossed that line by using a 25-amp fuse where a somewhat larger fuse would have been a better choice.  Nothing burned up except that 25-amp fuse which is a good thing.
And hey, I learned how to turn into my drive way in total darkness through the use of steering wheel Braille. And lucky guesswork.
Rick that 8 gauge wire will do 40amps nicely over that distance , but I am not sure what your loading it with , your headlights will pull 22 amps when all 4 are running , which is really close to your fuses rating , what else feeds off that wire ?
I guess at the end of the day , your fuse is there to protect the wire , so you could safely go to a 40 amp fuse.
Amperage (Amps)
Up to 1.5m (5 ft)
1.5m to 3m (10 ft)
3m to 4.5m (15 ft)
4.5m to 6m (20 ft)
5 A
18 AWG
18 AWG
18 AWG
16 AWG
10 A
18 AWG
16 AWG
14 AWG
12 AWG
15 A
16 AWG
14 AWG
12 AWG
12 AWG
20 A
14 AWG
12 AWG
10 AWG
10 AWG
30 A
12 AWG
10 AWG
8 AWG
8 AWG
40 A
10 AWG
8 AWG
6 AWG
6 AWG
50 A
8 AWG
6 AWG
4 AWG
4 AWG
100 A
4 AWG
2 AWG
1/0 AWG
Best thing you can do on these OLD cars is use a relay for things like headlights. The power will flow directly from the battery to the headlights and not through the whole system and headlight switch. You can use the existing feed wire from the headlight switch to trigger the relay.
Hello,
My re-arced (sp?) and re-lined original (OK, 1993 or older) front brake drum shoes returned from the "Brake Materials and Parts" place in Fort Wayne, IN on Friday. These shoes also got a repaint and a much tougher and higher temperature tolerant bonded friction compound. These 1993 shoes had a riveted friction material prior to me sending them to Scott in Indiana and I might have time later today to put them on for a test drive.
Its very bizarre with these front brakes. Some days, the infrared temperature gun says 275 degrees F. I pulled the Cat back into the shop two days ago and both front drums were at 150 F. I'm shopping for a new front drum hardware kit that might have better shoe retraction springs. IDK . . . confused here.
Hello,
The new front brake shoes got installed yesterday and I am very impressed. I can now almost, but not quite, lock up all four wheels with a very powerful use of the brake pedal. I think the still very new tires with plenty of traction probably won't allow the tires to skid but the braking action is very powerful. These new shoes can probably still use a slight outward adjustment toward the drum surface. I'm hoping that the auto adjustment feature on these front drums while braking in reverse driving will do these adjustments - they have that mechanism.
And the brake temperatures are now very normal. The IR temp gun earlier this evening shot about 95 F up front and 115 F on the rear drums. This hotter to the rear temperature is what leads me to believe the front shoes need a little outward adjustment.
I despise doing brake work but I do love how these new shoes are performing. I'm going to postpone putting a new brake hardware kit on the front for now.
Recently Browsing 1
