None of these companies sell a 12 inch long one ! They are all 9 1/4 . Looks like I will have to settle for the smaller unit
And justA , I can’t recore the old unit
The tanks and tubes are shot . 👍
  • Replies 329
  • Views 13.6k
Hopefully, the smaller core is the more modern aluminum design. Maybe the efficiency will make up for the lack of surface area.
The
2 hours ago, JUSTA6 said:
Checked all the biggie's, Nada. Found almost all start at 1968 that they can get. Found another place called brassworks.net that can build a 63-68 new one for ya. price. ??? But they include 1968 so I'm assuming a 68 will work for anyplace you can order one. Anyplace there that re-cores for ya?
Brassworks was 10 3/8 X 6 1/2 Biggest worry would be fitting the the inlet /outlet tubes through the firewall openings.
yes it is ! so it should work fine,
7 minutes ago, JUSTA6 said:
The
Yes Justa ! thats why i will pull the trigger on the core now !!! as my next job is to fill all the extra holes in the fire wall before i paint it !
and its the perfect time to alter the tail pipe locations if needed cheers
Tail pipe through the firewall???rofl Musta Justa missed Beer oclock...cheers Can't see The Boss liken this one.badGT
