1978 DMC Kentera
I found this on craigslist in Detroit. This is a new one on me too.
https://detroit.craigslist.org/okl/cto/d/1978-dmc-kentera/6614599694.html
1978 DMC KENTERA
condition: good
cylinders: 8 cylinders
drive: rwd
fuel: gas
paint color: black
title status: clean
transmission: other
1978 DRAPER MOTOR COMPANY KENTERA, KENT DRAPER A CUSTOM CAR BUILDER FROM THE 80'S TRIED TO START HIS OWN CAR COMPANY BY BUILDING RECYCLING CARS. USING F-BODY GM'S, HE WAS GOING TO HAVE SEVERAL VERSIONS FROM DAILY DRIVERS TO PERFORMANCE MODELS. THIS CAR IS HIS #1 PROTO TYPE PERFORMANCE MODEL THE KENTERA BUILT OUT OF A 1978 GOLD SPECIAL EDITION T-TOP TA AND TO GO OVER 200 MPH WITH FEATURES SUCH AS A 455 PONTIAC SUPER DUTY ENGINE BUILT BY EARLY PONTIAC RACING LEGEND GEORGE DELOREN BROTHER OF JOHN DELOREN FORMER PONTIAC GM AND HE STARTED THE DELOREN CAR COMPANY OF COURSE.. THE 455 SUPER DUTY HAS A SOLID ROLLER CAM, 12,5 TO 1 COMPRESSION, A ONE OF A KIND SHEET METAL 6 PACK INTAKE 3 HOLLEY CARBS AND MORE. THE TRANSMISSIONS HAVE A TOTAL OF 24 GEARS, IT HAS A 3 SPEED HOOKED TO A 4 SPEED (3 X 4 =12) AND A OVERDRIVE UNIT FOR (2 X 12= 24). IT ALSO FEATURES HERB ADAMS COMPETITION SWAY BARS, HYDRABOOST BRAKES 4 WHEEL DISC BRAKES, 12 BOLT POSI REAR END AND MORE,. THE BODY HAS MANY CUSTOM AND ONE OFF PIECES AS WELL. THE CAR AND KENT WERE FEATURED ON KELLY AND COMPANY TV SHOW, (HAVE A DVD COPY OF IT) ALSO MANY NEWSPAPER AND OTHER FEATURE SUCH AS THE CHICAGO TRIBUNE AND MORE. CAR IS PARTIALLY DISASSEMBLED AND NEEDS TO BE COMPLETED BUT WILL START RIGHT UP AND THE ENGINE WILL ROAR.. NEW WILWOOD FRONT BRAKES AND MASTER CYLINDER HAVE BEEN ADDED AND ARE NEARLY COMPLETE, NEEDS ADDING FLUID AND BLEEDING OF BRAKES. FOR MORE PICS AND INFO SEE; http://www.zombiemotorsports.net/the-kentera-.html
I'M SURE THERE IS MORE I AM FORGETTING AT THE MOMENT, I HAD BIG PLANS TO FINISH THIS CAR BUT THINGS KEEP GETTING IN THE WAY SO I THOUGHT I'D SEE IF ANYONE ELSE WANTED TO TAKE CARE OF IT. I HAVE CONTACT INFO FOR KENT AND GEORGE IF YOU GET THE CAR I WILL PROVIDE THAT AS WELL.. THERE IS WAY MORE TO THE STORY OF THIS CAR IF YOU GO TO THE ABOVE WEB PAGE AND CLICK ON THE CHICAGO TRIBUNE ARTICLE YOU'LL UNDERSTAND."
image.png.ccfb03b5e4262af6290e6cda5098ec9e.pngimage.png.348db5187462a1984359d223123d0ded.png
image.png.2e4f60cd3e8d3a1291ba5fcfc9d04678.pngimage.png.30ba273e0e178e8b7d1c635fff4697d1.pngimage.png.e52aea5b60df931881c48e7fe24cdbf3.pngimage.png.316aac0f73c951e5ac7d7b04f3fa9be0.png
