31pontiac's '31 Pontiac
22 hours ago, 31pontiac said:
Heat shields on. I also added X-Mat from Eastwood to deaden any resonance or droning the aluminum may have from the exhaust. An edging of 3M Panel Bond was added to keep water from getting between the X-Mat and the aluminum.
Everything looks really good Tim! It's all about the detail!! That's where most folks lose heart over the long haul!
  • Replies 208
  • Views 25.2k
  • 31pontiac
    31pontiac
    We now have a rolling chassis. IMG_9342.mov
  • I didn’t think the battery area would be so complex with battery cables, main power switch and vent tubes. The smaller wires are preliminary and will be cleaned up.     Battery cover was designed so
  • With the manifolds back on the engine, my brother and I spent 4 1/2 hours installing the rest of the exhaust system. It became a lot more challenging than either of us anticipated, but we finally got
A little detail I wanted was the “E-Z-Eye” glass bug used on GM (and maybe other) cars of the ‘50s and early ‘60s with tinted glass. After a long unproductive search online for the stencil, my brother knew someone who said he’d try to make them. He only cuts them, I must apply the vinyl stickers to the glass, use an X-acto knife to remove the letters and then apply Armor-Etch to etch the glass. First picture is from my ‘59 Bonneville.
Most people probably won’t notice it or care, but I do. 😉
Like the idea, you brought back memories from mid 70's. P Wouldn't think of making the glass logo. Nice
I refer to my previous post! DETAIL!! Oh the memories!
  • 5 months later...
After the final bodywork was completed and 1 final coat of epoxy primer, everything was sanded and sprayed with 3 coats of 2K urethane primer. Then more sanding 😬. Still have doors and hood to sand, but the body was sanded, masked, and ready for the first color, Wimbledon White on the firewall.
Looks good 31pontiac! Progress Is progress!
It’s going to be KILLER!! We are all going to enjoy the show!pop_corn
My brother and I spent most of Tuesday finally spraying some color. Planning on painting the body tomorrow. Here’s a few pics.
wow Tim ! your using one of those blow up spray booths !!! please tell us how you feel about it !!! i have looked at buying one , but cant find any thing big enough for the 63 !
