To 68 or not !!!
So
I got a day to play on the 68 again ..
I had made one corner section for the back screen , then clicked I had used 1.6mm sheet steel !!! Fail !!!
So I made it again out of 1.2 mm
And while I was making the passenger side , I went ahead and made the rest of the surround ….
I have rust alllll the way around that rear screen , so I am replacing the lot !
I have new glass so I used it to see how all the sections would sit
And went to replacing each section at a time ,,,,,,
  • Replies 394
  • Views 13.8k
    Thanks two lane, i only paid $400 nzd for these and i so could not justafy kre or eddy heads  My whole goal here is to help pontiac guys use what we have !! and not go blow silly money on afterma
  • NEWS FLASH: Thats her thinking to bro!
    More goodies arrived today !!!! 5 months after I ordered them!!!!   but the price was good and they got put on the slowest boat from USA to nz !!!!!  a complete tinted glass set for the 68 !
I completed half with a combination of tig and mig welding
And I so enjoyed my day !!!
I so enjoy panel work !!!
That's a huge project. Fantastic job mate! Thankz for sharing your mad fab skills.
Man I'm super impressed. That looks great bro! cheers
Thank you mate 👍
I managed to get some time on the 68 this weekend and got the rear window steel finished 🍻
Then I attacked the front screen!!!!
I was not happy !!!! It’s a mess ! And clearly a A body issue !!! Where they all rust !!!!
Having other chores that the boss was banging on about … I got the top sections bent and ready to cut/weld in
I will need to buy the cowl panel and the top dash panel
What i am finding is the parts are cheap! amd. jegs. summit. but its the shipping ! its a killer !!!
and i am struggling to get these purchases past the accounts department !!!!
right now my list is....
a rear parcel tray metal, cowl panel and dash top panel. sounds easy if i lived in cali !!!!
So much work but I love your attitude about it all. Yes, definitely an A-body set of problems.
  • 5 months later...
I am about to pull the trigger on my stoker crank and rods for my 400 Build
I am going with an Eagle 4.5 crank and some 6.800 bb chev rods , but no pistons at this stage . I am getting my 4x heads crack tested and ccd , before I set what dish I need in the pistons
I did my own ccd and I recon these 4x are 98 cc
But I want the machine shop to con firm that and crack test them before I go any further .
They seam to be in good condition .
And if all is good , I can get them to work out what custom pistons will suit .
Watch this space !
4x
Has screw in studs 1.6 ex and 2.1 intakes
Magnaflux or dye penetrant for your crack testing?
I would expect Maganaflux Rick, i will ask the machine shop when they get dropped off
More progess
On my 68 while I am welding on the Safari and humouring scammers !!!
The 400 block has a scat 4.5 inch crank and 6.7 bb Chev h beam rods and some stainless steel valves coming , trigger pulled after a lot of hard work to earn the coin !!!! And everting takes weeks to get to the bottom of the planet !!!
Ah ! And I have a Howard hydraulic roller cam with 4/7 swap on order from summit ! And same thing …. Waiting … should be here in November !!!
At this point I am using my 4x heads with 2.11 intakes and opening up The exhausts to fit 1.77
Anyone know of a 12 bolt A body housing for sale ? A chevelle one for a 68-72
I am not keen on using a f—d diff !
Something like this? There seems to be a bunch for sale in the Detroit Metro area. Some are car and some are truck rear ends.
https://www.facebook.com/marketplace/item/1567644218181568/?
Ah Link wouldnt open !
Ah opens now !
That one’s not going to fit
No ears on the diff head
And to narrow if it’s out of a 69 camaro
i can see i am gona have to start saving !!!!
