1964 Bonneville convertable restore
Oh that's awesome bro!
  • Replies 233
  • Views 18.9k
  • Bonneville convertable64
    Before pictures of the donor transmission. Notice identification tag location on mine. It should say p64 on tag.
    Excited to add the Bluetooth ignition timing system from Progressive ignition! Here she comes!
    One of the first things I noticed was transmission fluid leaking. We continued to drive the car and monitor the fluid level. Once the car was shipped to Florida I was ready to work on it. The transmis
On 3/9/2023 at 10:26 AM, Bonneville convertable64 said:
Well, it’s Kinda like spring cleaning but more like spring fixing. Another little  annoyance checked of the list after an all day job. Long ago i purchase a new fuel sender. It would max out at half a tank reading. I suspected it was bent and not able to float to full extension. The only way to do it right was pull the tank and drain it, so i did. It is not easy to guess how much gas is in the tank with a car that gets 10mpg. We did run out a few times.
   Getting under a tank with gas in it is not fun. After draining it i pressure washed the outside and inspected the inside. I cleaned up the mounting bolt threads so it will be easier if it ever needs to be dropped again. I used some wire to connect the sending unit with tank out of the way. It tested fine. Next,  I put sending Unit temporarily back in the tank and watched it move as I leaned the tank over. I could see it with a flashlight peeking through the fuel fill neck. As I suspected, it does not fully extend. I was able to bend the sending unit until it was correct. Problem solved!
Nice fix - well done. I also fitted a new sender and my gauge reads what it wants to. I am loathe to drop the tank and fiddle about with it but I think I'm gonna have to.
Photo shoot for a local popsicle business
very Nice :dancingpontiac:
Oh, now I see the popsicle. There were a pair of large breasts and then a blue car in the way.
What blue car Fitzy?
  • 7 months later...
Hey fellas!
Hi Del !!! hows life treating you :dancingpontiac:
6 hours ago, Bonneville convertable64 said:
Hey fellas!
Usually not a fan of underglow but that's hot!
