redgoat's 1967 GTO
2021 January
Hello everyone, been a member for a while now but never had a problem with my car so never really had to ask a question but that day has come.
I have an 08 Pontiac Grand Prix GXP with the stock 5.3L V8 in it, 8th digit C. My son threw a rod in it the other day and I need to just get up and running for now. I found a decent used 5.3L V8 GXP motor from and 06, they say Vin 8th digit is C with a one year warranty. Does anyone know if the 06 and 08 motors are the same. Not much info on the Web for this.
Thanks in advance. Chris.
Thank you for your reply. I forgot to mention yes, long block no accessory, and no core charge. It's going to be disconnect pull out put in and reconnect. I will actually be rolling back the miles on the car by 66K. They also have a one year warranty and do not require mine back for a core so I'm going to send that one out to be rebuilt. Did not blow any holes in the block so hopefully, it has no stress cracks in it.
Yup! Should be good the ECM is the brains that reads and controls the other sensors. Tells them what to do. The only issues you could see are possible with the MAF on the throttle body. Sometimes they changed the throttle body from one year to the next and the MAF mounting will be different. If that were to occur, either replace the throttle body with your old one or get the correct MAF for that year throttle body, the pigtail should be the same.
Before you take the engine out take good pictures of how the wiring harness are laid out for everything. Fuel injectors, coolant sensor, MAP, IAC, IAT, crank sensor, coil packs, EGR, etc!
