Installing a 8 Speed auto Transmission in your Pontiac 8HP
I am looking to install a 8HP transmission in my second gen Trans Am. The ZF 8HP is a highly acclaimed 8-speed automatic transmission designed by ZF Friedrichshafen in Germany. Widely considered one of the best automatic transmissions ever made, it is revered for its lightning-fast shifts, superior fuel efficiency, and ability to handle massive amounts of torque. [1, 2, 3, 4, 5]
The computer to shift it is here: For a plug-and-play installation tailored for a classic, carbureted engine, the Sound German Automotive (SGA) 8HP Transmission Controller Kit is the gold standard.
I know the adapter to mount it to the engine is here: https://www.adamat.com.pl/en/pontiac-400-kit-for-dodge-challenger-charger-hellcat-zf-8hp70-8hp90.html
Has anyone done this swap yet?
I haven’t Cole , but I am installing a 6l80e and I know I have to change my rear end gears to 3.64 or the over drive ratios will make my engine run at to lower revs
You doing a 8 speed will encounter the same issue
Keep us posted with your swap 👍
And funny that I justA bought a new Chinese van ! It’s Ldv g10 and it has this transmission !!!!
It’s powered by a turbo charged petrol 2.0l engine and it’s changed gears 4 times justA going through a set of traffic lights !
But where I find it really good
Is up hill pulling power !!!!
It’s the 8hp50
You will be wanting the 8hp90
Likes in my 2016 hellcat !
And you will certainly be cutting your tunnel out to make it fit ! They are way bigger, unless you are using the 8hp75
Which will fit
But only justA
Engine& Transmission
I've never heard of this trans. (but I don't get out much) So you have a German trans in your Chinese Van?
Yes justA ! And a zf diff , the motor is a vw one !!! Crack up aye !!!!
Edited by Topless
ANYONE tried to install one in a second gen firebird? Adapter supplier indicated a guy in CA ordered one. The adapter is sold tru sales@seemslegitgarage.com, or Seemslegitgarage.
They indicate the adapter takes 6 weeks to build and cost $1575.
I need to know how it fits the tunnel and ground clearance for the pan.....
