Water pump height.
Hi everyone,
I noticed that my water pump was leaking when I put the car away for the winter, so now that it's starting to get a little warmer I thought I would replace it. When I went to find a replacement it looks like they come in two heights one is just listed as "standard" and the other is listed as a 4 15/32" (or 4.469") height. I have a 1969 G.T.O. with a 400 c.u. motor. Do I measure from the block to the where the fan mounts or the front of the pump to the fan mount?
Thanks for any help.
https://www.rockauto.com/en/moreinfo.php?pk=11203645&cc=1256363&jsn=1671
https://www.rockauto.com/en/moreinfo.php?pk=948816&cc=1256363&jsn=1670
18 hours ago, Federated52 said:
Hi everyone,
Todd, you get that dimension by measuring from the gasket sealing surface of the pump to the mounting surface hub where the pulley mounts! An easy way to do that is take a straight edge across the hub flange, minus the pulley, and measure down to the gasket surface of the water pump.
Ok, That's what I thought, just wanted to make sure. Thank You.
Thank you, from what i measured it is a 4" water pump. Thank you for all the info.
