Motor oil and zinc content
For those with flat tappet engines, what oil do you use and is the zinc content of concern to you when you choose an oil? Almost certain that I'm going with Amsoil Z-Rod 10W-30 for my next change. Just not sure if zinc is a real concern in a stock 1964 GTO that is never pushed too hard. Only street driven.
Zinc is most definitely a concern in pre 1980 (approximately) engines. Zinc in engine oil forms a protective film/lubricant on metal parts to prevent metal to metal wear. That said while Amsoil is a fine oil, in my opinion Shell’s Rotella is a better choice.
Sadly the lack of ZDDP (a.k.a. zinc dialkyldithiophosphate ) in today's modern oils is what provides the molecular protection preventing metal-to-metal contact in older flat tappet engines.  So selecting an oil brand with adequate ZDDP or adding a ZDDP additive is becoming more imperative today.
The reason ZDDP is going away is that OEM manufacturers are expected to warranty their new car & truck emissions systems to last 100,000 miles or more by the federal government. In order to do that, the car companies have to eliminate phosphate contamination in the catalytic converter, which can come (in part) from the motor oil.  Therefore the oil companies have to reformulate their gas and oils to eliminate phosphates, but in doing so, the ZDDP goes away too.
Brands like Amsoil, Brad Penn, Lucas Hot Rod & Classic Car Oil, Royal Purple, Valvoline VR-1, Mobil 1 Synthetic, and Pennzoil synthetic and conventional oi are all suppose to have high levels of ZDDP in them. Note: I intentionally left the diesel oils like Rotella and Delo off the list, this is just a conventional motor oil list, not diesel oil. A lot of guys swear by the Delo and Rotella. I am just trying to keep the list to regular motor oils.
While the brands I've listed work fine, they tend to be expense too. So I also look for oils with an API rating lower than the current standard - which is SN. If I can find something between SF-SL, I personally buy it for my '72. Sometimes I get lucky and find cheap Wal-Mart, Meijer, or gas station private branded oil with one of these ratings. Its still a needle in a haystack search, but sometimes I am rewarded.
So this is a long winded answer to your question, but now you have more information.
  • Like 2
I understand there is usually a lot of confusion around this subject and the direction Frosty is pointing is good and logical. But at the end of the day Amsoil is twice the price of Rotella T6, has no more zinc in the formula than Rotella, has a lower base number, which means a great deal and has a lower viscosity rating, which is very important.
Question, in the same engine, running the same temperatures under the same loads using the same brand of oil which is better 10W30, 10W40 or 5W40?
I remember the late Pontiac historian John Sawruk was asked this question. His response was 10W30 was preferred over 10W40. He also recommended conventional oils over synthetics for stock or near-stock engines. BTW 10W40 oil works fine too.
John said the 10W30 was thinner, so cars with hard starting or residing in cold weather climates could to start easier. Since 10W30 and 10W40 were both spec'd for Pontiac engines back in the day, and not other formulas, he said stick with what works. He said to stay away from the 5Wxx oils as they were a thinner viscosity and Pontiac engines had such loose tolerances (as compared to today's modern LS engines) that thinner oils could get through these tolerances and cause leakage. Nor could they reap the benefits of a 5W weight oil since the last Pontiac V8 was built in 1980.
Also, he recommended staying away from synthetics for similar reasons. Early on synthetics could cause leakage and seal swelling. The swelling issue has been largely fixed by oil OEMs by reformulating their oils. However an expense synthetic is not recommended for a stock Pontiac engine unless you have an engine builder who has tightened up the tolerances and recommends it. Besides why spend the extra money for no apparent benefit?
7 hours ago, vwalburn said:
And what is the zinc/phosphorus levels of Rotella T6? Have heard a lot about zinc levels going down in diesel oils as well.
Both Amsoil & Rotella T6 are 1000 ppm because they are synthetic. While Rotella T5  is a synthetic blend, part synthetic part conventional, which has 800 ppm, more than enough.
Sorry Frosty, I meant it rhetorically, but your answer is correct. To expound on it further if I may? What I was getting at was, it depends on bearing clearance more than anything else, yes! My 302 Z was a loose engine for bearing clearance on purpose. I ran 20W50 racing oil. The 3600 Buick is a very tight motor so I run 5W30. Most people don’t have a clue about that issue or why you really run different weight oils.
You might find this of interest. About 15 years ago I presented a paper to our then VP over engine oils as to a theory on particulate in engine oil and it’s impact on oil viscosity in the bearing journal. He provided the money to run several test to prove or disprove the theory. It proved to be correct. As engine oil gets increasingly dirty by particulate or soot it starts to run into other particulate in the bearing area, elevating local bearing oil temperatures due to friction. This action causes the viscosity in the oil of the bearing area to decrease quite a bit. Thus this is one of my main reasons why I still change oil at 3000 miles.
6 hours ago, vwalburn said:
So, if synthetics are out, Amsoil and Rotella T6 are out because they are synthetic. So, of all the current-rated oils, what oil would you use if no synthetics and no access to older-rated oils? I'm not a fan of additives added to the oil.
VW, if you don’t what to run the full synthetic oil, 1000 ppm Zinc, then consider the Shell Rotella T5 synthetic blend. 800 ppm Zinc, low ash, but still has some ash, which is good for the older motors as well.
Last Indian, I do enjoy our back and forth discussions. I think we both learn something in the process.
So let me ask you this, do you recommend running an engine cleaner - in an attempt to clear all the sludge and carbon build-up - like you mention above - prior to a fresh oil change? If so, how often do you do it? Every oil change, ever other oil change? Every 10,000 miles?
I enjoy our discussions as well, you’re a knowledgeable young man!
No I don’t generally care for engine flushes. They reduce every needed oil component the engine needs to operate and be protected. While a multitude of folks use them without incident that doesn’t make them good.
If I want to flush an engine I do so in the same manner we did or do at work, I use new oil and a new filter. Nothing, and I mean nothing cleans an engine better and safer than TBN, (total base number). If I still had access to my data and pictures of the testing I ran, and could show you the impact TBN has on an engine’s cleanliness and condition, it would blow you away, it’s that dramatic!
When I do flush an engine in this manner I drive the car for 100 miles and then do another complete oil change. If I feel the engine is exceptionally dirty, I’ll do a second flush with fresh oil and filter for another additional 100 miles.
For me now that is rare though, as I said before, it is rare for me to allow a oil change to even get to 3000 miles, which means when I change the oil the TBN is still higher than the TAN. Which means the oil was still in an active state of protection and cleaning.
My two cents worth, ok maybe three cents!
Great article Frosty!
A littel further explanation. We have run a fleet test in Vegas taxi cabs for decades, so around 2008 a colleague and I had developed a product some 5 years earlier. We had a variation of it that we were considering for aftermarket and wanted to test it. The product was contained up in the valve train and slowly released over time increasing the total TBN of the oil in the engine. The results were awe inspiring! These motors had 130000 plus miles on them and the valve trains were needless to say a varnished mess. After running this product for one year of oil changes the valve trains weren’t just clean, they were bright metal again.
