New Found Power.
360, you are right, light is a light, but the timing tab that the harmonic moves past can get knocked out of position. The only way to verify it’s accuracy is to do the indicator check for TDC.
Isn't the timing tab on a Pontiac block cast into the block? I just wanna make sure i'm not screwing up the terminology. I can see the balancer separating and I'm gonna mark both sides and check it periodically.
  • Replies 51
  • Views 6k
  • 360 if you need a timing light I have a spare and I don't use either anymore since, as I've explained to Justa, the wife's allergies are why to bad to go back to the older ones, she needs cabin air fi
  • Glad to help, really what good is a timing light setting on a shelf doing nothing? 360 I just need to know where you want it sent, shippings no big deal. Besides after seeing what bitch Irma did
  • You guys are to kind, but thanks! Justa being a good brave, that's what the chief (Pontiac) would want!
Right you are 360! I always forget Pontiac does it that way as opposed to Chevy. That said, makes it even a little more necessary to follow the process and verify exactly where TDC is. So 10 degrees advance is 10 degrees. To do this right you’ll need a degree wheel, the proper indicator and patiences.
