Mod list: (Updated 1/9/12)
Exterior Modifications:
Speedline MIstral 6's 17" x 9.5"
Kumho Ecsta 275 x 40 x 17
8000K HID low beams.
8000K HID fog lights.
60LED Switchback DRL/Turn Signals.
Debadged, trim delete and rear filler panel is now devoid of the firebird name and logo.
Interior Modifications:
Corbeau CR1 race seats
PLX Wideband gauge in central AC vent
Weight Reduction
Performance:
Whisper Lid
Intense S1X NA Cam: 212º/216º .556"/.546" 113º LSA (With 1.7 ratio rockers)
Yella Terra 1.7 Platinum series roller rockers
PAC 130# springs
60°Inclusive ported heads and intake
10:1 Compression
LS6 Fuel Injectors w/ FAST spacers
Manton Pushrods
LS7 lifters
Fabricated Valve Covers
Force Fed Fabs Longtube Headers
3" Spun Metallic Cat
3" Electric cutout
3" dual out turbo muffler (Dynomax)
Suspension/Chassis:
Front:
BMR 32mm Solid swaybar + Poly endlinks/bushings
PARacing Tubular K-member RR
HAL QA1 12-way coilovers
Rear:
LS1 19mm swaybar + Poly endlinks/bushings
UMI Performance LCA's
UMI Performance Adjustable Torque Arm
HAL QA1 12-way shocks w/ WS6 rear springs
Drivetrain:
Aluminum Driveshaft
Yank Torque Arm Relocation Cross member
TCI Super Street Fighter 3800 stall w/ 2.1 str
4L60E built by Richard at Precision Transmissions in Amarillo, TX
Hayden 1405 trans cooler
Electronics:
HPTuners
PLX Wideband
CDT Door Speakers: CL-61CV.2
CDT Sail Panel Subwoofers: HD-6M DVC
To-Do List:
Install ram air hood, build air box.
Break into 13's NA.
Collect parts pile for T-56 build. *Clutch kit is all that remains*
Afterwards, build parts pile for boost build.
Original post:
Figured I'd post up what I've been working on over the past few months. I'm not wanting to get into the debate as to why I'm modding a V6 or why an LSx would be faster etc. etc. I prefer having a good discussion, but you don't have to beat me over the head with an LSx stick.
Not doing this to set records, just make the original engine a bit better and get some more life out of it before I move on to something else after I get my degree. I'm doing this to get my feet wet, and this engine is known to be able to take a beating. I've never torn apart an engine until this and I'm making sure it is done right.
2000 Pontiac Firebird
Torn down at 140K miles initially planning to replace a leaking intake gasket and install a cam.
Before the teardown the only performance mods the car had were:
Longtube headers
TSP Catback
Lid
Aluminum DS
Dyno'd 169hp & 184tq on a mustang dyno before I pulled it apart. Engine really was showing its age:
As you can see, the oil sludge was pretty bad. I changed with synthetic oil almost religiously on this car, but I have a feeling that the original 60K miles in only 2 years from the previous owner didn't help much. I have a feeling they might have skimped on oil changes here and there. Heck I had to have the trans rebuilt a month after I bought it.
So I decided to have the whole assembly cleaned, had the rotating assembly and everything taken care of, and sent the intake and heads to be ported some (just to liven it up) clean it up, tap it for the new rockers and mill the guides to allow for higher lift.
Here's the mod list so far:
Aluminum driveshaft
Whisper lid & K&N (K&N is good for +100hp right? :lol: )
Force Fed Fabs stainless longtube headers
Texas Speed & Performance Rumbler catback
32mm front and 19mm rear swaybars
Intense Racing S1X NA Cam: 212º/216º .556"/.546" 113º LSA (Profile with 1.7 ratio rockers)
60*Inclusive hand ported heads and intake
Yella Terra 1.7 platinum roller rockers
UMI LCA's, PHB
PA Racing Tubular K-member
HPTuner suite
Where it sits now, waiting on pushrods and valve covers:
Step 1, assemble front k-member and suspension components:
Step 2, begin mating dance and observe proper language to adhere to the ceremony and not take away from the moment:
Step 3, bring mated pair to their new cradle and allow them to consummate their marriage:
9:30 AM
Started clearing a path to the car, half the bay is filled with the old OEM parts.
10:00 AM
10:15 AM
10:45 AM
11:00 AM Fighting a heavy engine and trans with a jack up front that keeps slipping down the smooth tubular K-member proves to be very challenging to line up.
2:00 PM Time to shower up and head to work.
Heater hose mod, front needs alignment so nose is still a little up in the air.
In the Duke's Pit of Despair!
Coil bracket mounted to firewall, had to move it an inch over towards the intake as the prong on the coil pack was on the brake booster.
Looking like a car again!
8 months in the making. As of 9:00 am, the car finally breathes again.
9298.jpgView Video on FQuick
Still need to check the pushrod preload after it idled for a few minutes, neighbors have some contractors doing some work from their garage and they were both looking outside down the street like
Sounds like I have a freaking pro stock car in my garage
I also need to install new pads/rotors and bleed them and get it ready to take it to get it aligned. Gotta hook up HPT as well.
Mods:
Whisper Lid
60*Inclusive ported Heads and Intake
Intense S1X NA Cam
Manton pushrods
FFF Longtube headers
TSP Rumbler Catback (not hooked up in vid)
TCI 3800 stall
Aluminum driveshaft
Trans cooler
BMR 32mm front, LS1 19mm rear
UMI LCA's & Adj. PHB
B4C power steering Cooler
  • Replies 443
  • Views 47.2k
  • Got out and enjoyed some partly cloudy weather.  Wish I had more time to mess around with the shots, but this was my favorite one out of the bunch!
  • [ChaosweaveR]
    [ChaosweaveR]
    Brruuuhhhhhhhh.
  • Second full day of going at it. Had to run some errands here and there, did some more cleanup and wrestled the engine around for a little while. The cardboard came in handy since I could just slide th
You should swap to a L26 intake manifold. Lighter, and 75mm inlet. :lol2:
thats crazy nice! great job on the build! any boost in the near future?
Man, the inside of that motor was haggard when you started.
I've done my LIM gasket, but I've never taken the heads of my motor, hope it's not that bad when I rebuild it. Awesome to see it's up and running.
Can't wait for dyno and 1/4 #'s!
moved to progression.
Ooooo looks nice! :D
Thanks, no boost on this motor. Milled the heads and running thinner head gaskets to get 10:1 compression, up from the 9.3:1.
I'm going to start saving for an LLT swap and maybe give it a snail or two for good measure.
thats awesome dude kudos to you :D
I had to listen to the sound clip again.
Such a beast sound for a six.
I love it.
Wow great job! :DB):welcomeFP:
:D
nice! N/A high compression. Should help you really well with your acceleration. is this strictly a 1/4mile car? just wondering. :D
That's AWESOME.... Wish I had the time, money and knowledge to do something like this...
Sounds great!!! You did an excellent job man.
So you did all this work, and your going to do a swap later? How later?
Probably in a few years, this was just to keep me happy for awhile.
It'll give the market time to catch up to the LLT engine and maybe whatever comes out after that. Doing pharmacy school this next year so that gets financial priority.
wow!! Crazy amount of work! Very good job! Sounds like a beast and probably will be a beast!
Wanna come rebuild my Monte Carlo's engine? :welcome:
The LLT motor is pure secks.
Wonder if the FWD version found in teh new body Malibus and Auras will tuck into the GA's engine bay...
It is a 60*V6 after all.
... hhhmmm....
is that the 700R4 tranny?
god i hate that trans. i killed 2 of them in my camaro.
Nope, 4L60E.
with the new cam what are you going ot use to tune?
do you have a wideband? wonder what your AF is now that you have a hot cam in that thing.
Actually it is a daily driver, wanted to run a little more compression to help make a cleaner burn of the fuel, more power on tap and just get it a little more up to date.
It will see some 1/4 mile time, but it is a street/strip car.
Can't be as bad as the weaksauce 4T45E trans. Ugh...
HPTuners and PLX Wideband
Car had a TSP generic tune before which helped some with idle and such, but just driving it around easy it was pulling timing. That'll be remedied soon.
what state are you in? sorry if you have said that.
Also how long have you been using HP Tuners? or are you paying a shop?
I would really like to know how to use that software. the best i ever did was use an APEXI SAFC II to hold myself in a certan AF
do you have any videos of it running? bet it has a sweed lope to it.
Texas
Just got HPTuners hooked up, doing it myself.
No other videos with the current setup, but I have a dyno vid from before, just an intake longtubes and catback. Vid is loud.
8137.jpgView Video on FQuick
Amazing progression thread!!!
