1997-2003 BCM GT --> GTP Swap help!
So I have a GT and I'm in the process of swapping the BCM off of a GTP to get the HUD working, I hear if I disconnect the BCM I will trip safe mode... What do I need to do to swap it correctly?
I have never needed to do anything with my BCM, but there is a company that can most likely help answer your question. https://newrockies.com/
There are a lot of things I have deleted from my GP & some have been security aspects, but not all and none have been removed off the BCM
As a side note, the GPs did not have to be a GTP to have HUD.
I wish it was this easy I have a 2001-03 and they removed the pigtails for the HUD and HUD switch off the harness sadly
There is place up here called Morad Parts. https://moradpartscompany.com/ they have always been good to deal with. I see the have a couple BCMs, but what they may have that they don’t show online are wiring harnesses. You might call and talk to them. They have always been quite knowledgeable & helpful. Ed is the owner, if you can talk to him.
IF YOU DO NOT HAVE ACCESS TO THE TECH TERMINAL, A 30 MINUTE RELEARN PROCEDURE MUST BE PERFORMED BY FOLLOWING THESE STEPS:
PLACE A JUMP PACK ON THE VEHICLE. DO NOT LET THE BATTERY DROP BELOW 11.5 VOLTS.
TRY AND START THE VEHICLE.
RETURN THE KEY TO THE RUN POSITION.
WAIT 10 MINUTES. (10)
TURN THE KEY FROM RUN TO OFF.
RETURN THE KEY BACK TO THE RUN POSITION.
WAIT 10 MINUTES. (20)
WAIT 10 MINUTES. (30)
AFTER THE FINAL 10 MINUTES, RETURN THE KEY TO THE OFF POSITION. THE NEXT CYCLE OF THE KEY WILL NOW RE-LEARN THE PASSLOCK DATA INTO THE REPLACEMENT MODULE.PERSONALIZATION SETTINGS IN THE DRIVER INFORMATION CENTER MAY NEED TO BE RESET. PLEASE CONSULT YOUR OWNER'S MANUAL FOR VEHICLE PERSONALIZATION.
