Clicky
2015 March SE Pontiac of the Month
91Firebird's 1991 Firebird Formula
Sponsor the POTM                       VOTE FOR THIS MONTHS
How To Reset/Relearn TPMS w/New Sensors
  • Please log in to reply
1 reply to this topic
#1 BAMBAMM
BAMBAMM
    Century Club
  • Regional Mod & Supporting
  • 458 posts
0
  • Gender:Male
  • Year:2009
  • Car:G6
  • Trim:GT
  • Engine:3.5L VVT
  • Style:Sedan
  • Color:Performance Red Metallic
Posted 07 July 2010 - 12:05 PM
I haven't tried this yet, as I don't have the money to get new sensors into the wheels and tires. Any additional input would help, but this is from a reliable source.
http://www.ehow.com/...e-rotation.html
Tire pressure monitoring systems must be reset or "relearned" after a tire is changed or rotated. In a perfect world, your dealer or service professional will have performed the procedure for you, but if he hasn't, you can do it yourself. The process requires releasing a large amount of air from your tires, so you'll need to have access to an air compressor. The process is the same for all Pontiac G6 models, 2005 and newer.
Read more: How to Reset Pontiac G6 Tire Pressure Sensors After Tire Rotation | eHow.com http://www.ehow.com/...l#ixzz0t17l0Nn6
Things You'll Need:
Tire air gauge
Air compressor
Step 1
Make sure that your air compressor has enough air to re-inflate your tires. If you don't have an air compressor, park your G6 near an air machine (often found at gas stations) before beginning the process.
Step 2
Turn your engine off and set your parking brake. Turn the ignition to "On" without cranking the engine.
Step 3
Press and hold the "Lock" and "Unlock" button on your keyless entry remote for 5 seconds, until the horn chirps twice.
Step 4
Remove the valve stem cover from your driver's side front tire. Depress the center stem to release air from the tire for 10 seconds. Wait for the horn to chirp (this can take up to 30 seconds) and the exterior lights to flash.
Step 5
Repeat the process for the passenger's side front tire, then move on to the passenger's side rear tire, and finally to the driver's side rear tire.
Step 6
Listen for the two horn chirps after performing the process on the driver's side rear tire. This signals that the resetting and relearning procedure is complete.
Step 7
Check the tire pressure for each tire, and then add enough air to bring it to the specified level. Inspect the tire specification sticker on the driver's side door jamb; the recommended tire pressure varies depending on your G6's tire and wheel size. Replace the valve stems when you are finished.
Tips & Warnings
If your G6 does not have keyless entry, you can still reset the system yourself. Hold the "Info" and "Reset" buttons on your dash until the message "Tire Learn?" is displayed. Perform the procedure as outlined in these steps, and wait for the "Learn Complete" message to display. Remove the key to complete the process.
Posted Image
#2 Ringo64
Ringo64
    It's Good to Be King
  • Root Admin
  • 11,028 posts
30
  • Gender:Male
  • Name:Jim
  • Gender:Male
  • Year:2006
  • Car:G6
  • Trim:GT
  • Engine:3.5L LX9
  • Style:Coupe
  • Color:Black
Garage View Garage
Posted 07 July 2010 - 12:14 PM
Step 3
Tips & Warnings
I was reading and got to step 3 and was like hope nobody has problems with their keyless like I do where the unlock doesn't work all the time and you have to hold it down anyway. Then I read the tips and was like good there's another way about it.
I don't have the tire pressure sensors in my 6 but seems like a good thing to know for those who do!! Good job Bam!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
