hard starting
70 lemans with a 350, got it a year ago had to adjust choke on a eldelbrock barb then it started right up without loading up. now hard to start checked coil was weak put on a new one still hard. I spin it and it spins a while when I stop spinning it , it will go to fire up. got a pertronic in the distributor and wondered if you had any experience with the same thing happing. seems to run ok when it starts just not use to a car starting that way, about the same hot or cold.
Seems like your Pertronic distributor has no 12 volt power DURING cranking. Or, it has about nine volts of power through a ballast resistor - from use with a pre-HEI distributor - that is too low to operate the ignition module in the Pertronic unit.
Give your new distributor a full 12 volts of key on ignition power during and after cranking.
ok i'll check, ign was put in a while ago I just bought the car last year
That sound like a ignition switch worn! the contacts are tired Bob !
these old girls will have nasty worn contacts within the ignition switch !
and what you have to do is a process of elimanation !
pertonics are wayyy bullet proof !
new switch would be my first fix !....or
because i am a tight arse ! pop the switch off and carefully open the casing of the switch and clean the contacts !
Question: is this a cold stsrt or a hot start issue or both?
both ,was fine just started doing this
its wired termina hot to coil and wiee to ign in distributor, i got 11.9 volts going to try wiring a elay tomorrow fo gve it ull from batt, took reading at batt 13.4.
is that rhode island gaelic ? rofl bob
no just not checking spelling lol
replaced ign switch on steering column stilldoing same thing, saw on a stie a wire comes from starter to coil for full voltage. not on my car.
i stand corrected, went back under with glasses found a wire to the side of starter and empty terminal on starter cable stud. getting a terminal tomorrow and hopefully sovles the problem i'll let you know.
