How to get the backup Lamps working BW T-10 have the switch: Where to source the wiring harness??
I have the switch, sourced from M & H Electric Fabricators INC. need the installation bracket and the rest of the wiring harness.
The white lights under the rear bumper work when 12vdc is applied.
Is this a Salvage yard ITEM??
Clutch Cargo
910-448-2576
Solved by Frosty
  • Solution
Check with Frank’s Pontiac Parts for a used harness. I would also like to believe that either M&H or Lectric Limited would have a new OER replacement harness.
All good suggestions,
Franks checked for a car with a 4 speed and no luck there.
M and H I've asked with no response, I will Google Lectric for contact info.
Clutch Cargo
m and h are real slow if ever answering e-mails. justa my experience.
  • 5 weeks later...
Back up lamps now work with my Hurst!
