Classic Pontiac Restoration Tips: Breathe New Life Into Your Ride
Restoring a classic Pontiac is more than a hobby — it’s a labor of love. Whether you’re rebuilding a barn find, bringing a family heirloom back to life, or just itching to give your GTO, Firebird, or Bonneville a second chance at glory, the process can be incredibly rewarding.
At Forever Pontiac, we’re passionate about preserving Pontiac’s legacy. That’s why we’ve put together this guide full of practical, tried-and-true restoration tips to help you on your journey — whether you're a weekend warrior or diving into a full frame-off resto.
1. Plan Your Restoration from the Ground Up
Before you turn a single wrench, assess the vehicle’s condition and outline your restoration goals. Are you aiming for a concourse-level show car or a dependable driver? Knowing your goal will dictate how much time, money, and effort you’ll need to invest.
Start with a complete inspection:
  • Check the frame and body for rust, rot, and accident damage.
  • Inspect the engine, transmission, and rear end for rebuild feasibility.
  • Take note of interior parts and trim pieces — many of which are hard to find for vintage Pontiacs.
A detailed plan can help you stay on track and avoid costly surprises down the line.
2. Join the Right Community
Restoration is much easier when you’re not alone. That’s where the Forever Pontiac community comes in. From model-specific forums to build threads, we’re here to answer your questions, share experiences, and help you locate parts.
👉 Join Forever Pontiac Forums to connect with fellow Pontiac lovers.
3. Document Everything
Take photos and label parts during disassembly. Keep track of bolts, brackets, and connectors using baggies or organizers. This not only helps with reassembly, but also makes it easier if you sell or show the car.
Bonus tip: Share your progress by starting a Progression build thread on Forever Pontiac — it’s a great way to get feedback and motivation!
4. Use Quality Reproduction Parts — or OEM When Possible
While many reproduction parts are available for classic Pontiacs, original equipment parts tend to fit better and retain value. But finding those parts can be tough — and expensive.
That’s why we’ve compiled a community-driven list of salvage yards and suppliers to help you locate rare or discontinued parts.
👉 Browse our U.S. Old Car Junkyards List — it’s a goldmine for anyone hunting down vintage Pontiac components.
5. Address Rust the Right Way
Rust is the enemy of every restoration. Don’t just “bondo over it” — cut out and replace rusty metal, especially in structural areas like floor pans, rocker panels, and frame rails.
If you’re dealing with surface rust, media blasting or chemical treatments can be effective. Just remember to prime and protect the metal quickly to prevent flash rust.
6. Upgrade Where It Counts
While keeping it stock has its appeal, certain upgrades can improve safety and drivability — without sacrificing the car’s character:
  • Disc brake conversions
  • Modern ignition systems
  • Upgraded suspension for better ride and handling
  • Hidden audio systems that retain a vintage dash appearance
The Forever Pontiac community is full of modded builds, so you’re sure to find inspiration whether you're going OEM or resto-mod.
7. Be Patient — And Enjoy the Process
Restorations can take months — or even years. Don’t rush it. Set realistic timelines and budgets, and remember: every bolt turned is a step closer to getting your Pontiac back on the road.
Share Your Build on Forever Pontiac
Nothing inspires fellow enthusiasts like seeing your progress. Head over to our Garage section and start your restoration journey with the community.
And if you're stuck on a part or supplier, the junkyard list is the perfect starting point.
Let’s preserve Pontiac history — one restoration at a time.
  • Ringo64 pinned this topic
