vacuum advance 1970 350 lemans
just set the timing and when I connected the vacuum line to advance it didn't change , time for a new advance unit?
Sounds like it. With the vac line connected and you rev the engine, do the timing marks change? Is the line in good condition - no cracks or holes?
The timing marks will move of course due to both centrifugal & vacuum mechs. If you rev the engine gradually that should activate the centrifugal. When you gently back the revs off a little you'll see the vacuum do it's thing, ie. higher vacuum will cause the marks to move again. No movement means a new can.
Also, if you suck on the vac line you should feel plenty of resistance. No resistance is probably a damaged vac diaphragm.
Edited by Fitzy
who ever set it up had it to the wrong port I changed it and its working fine.
  • 3 weeks later...
Thanks for sharing your solution with us. Can I assume the vacuum advance was connected to ported vacuum instead of direct vacuum?
yes wrong port
