70 lemans mirror control
the passenger mirror on my 70 lemans has adjuster on drivers door that doesn't work was told there is a wire that is broken, can I get the wire is it a easy fix? thanks
You would have to trace the wire all the way to the mirror.  It could be the motor in the mirror is bad.  The movement points will be where the wires go into/out of both doors and usually have a BOOT to cover.  You can easily test with a 12-18V battery from your drill or other hand tools. Good luck.
Is it electric or simply cable driven? I am confused.
the guy I bought the car from said its a cable wire
