Speedometer bullet and gear
Hello,
 I have a 62 Bonneville that has a leaky speedometer bullet. The gear has 18 teeth, but I can only find a new gear with 19 teeth.  Can I use the 19 tooth in the bullet? If so, what happens to the speedometer? ANy help would be appreciated.
Thanks
Where have you looked for a new speedometer gear? Classic Industries has the brown, 18 tooth gear in their current paper catalog on pg 82 for $8.99 part number "G8796".
https://www.classicindustries.com/shop/search/?q=G8796
Thanks for your reply.  I actually need the bullet and the seals I have found the gear but I need the whole thing.
Thanks all problem solved.
What was your solution? Where did you find the bullet you needed?
I got it on Obsolete oldsmaobile website
Which one?This would be a good website to know.
