projector lights
has anyone done a projector conversion to stock headlights do not want to pay for premade ones if can do it myself
Edited by outlawmars
My son and I installed project headlights into his Hummer H3.  I plan to install Octane Lighting T3-replacement H4 Halogen bulbs on my '72 Lemans later this spring.
We purchased a kit that fit the Hummer, so we didn't have to fab up anything. It came with its H4 fitting bulb and wiring harness that hooked up to factory harness. I still had to run some wiring to the fuse block under the hood too. It was easy to install but it required removing the grill and headlight bezels to get the lighting harness and route the harness. Bottom line it will be a little time consuming.
