dual line feul sending unit
I am in need of information on where or how I can get a replacement dual line sending unit ofr my 1968 Pontiac Bonneville
or is there anyway I can set up a single line....open to all ideas and any info would be greatly appreciated
You must have either a convertible or air conditioned car. Contact Frank's Pontiac Parts in 29 Palms CA.
According their eBay listing  - https://www.ebay.com/itm/67-68-Pontiac-NEW-Replacement-Single-Line-Fuel-Sending-Unit-Catalina-Bonneville-/172797673459
"1967-68 Pontiac Replacement Single-Line Fuel Sending Unit
This listing is for one new replacement fuel sending unit.  After years of selling these sending units on our website, we decided to reach a larger audience by putting them up for sale on eBay.
(includes rubber gasket)
Fits All 1967-68 Pontiac Full Size Cars
Catalina, Ventura, 2+2, Bonneville, Executive & Grand Prix.
Type: float style
Flange Size: 3 5/8"
Height: 6" fit into the fuel tank
Lines:  1 single 3/8 fuel line 3 1/4" long
These sending units are a replacement unit, not an exact reproduction.  The original unit was a canister type, but they were prone to failure.  Is the float type better? Yes, it is more reliable, but since the fuel tank does not have a baffle the fuel gauge will change when you go uphill, downhill or around a corner (like most other cars of the 1960's).  Also the fuel line is a bit shorter (use a little longer fuel hose).
We are selling dual-line (vapor return line type) and single-line fuel sending units (the type in this listing) on eBay in separate listings.  What type do you need?  As a rule,  convertibles and cars with air conditioning have the dual-line unit and all the others have the single-line, but GM was not perfect (say it isn't so), so it is good to check your car first.  We do not accept returns on electrical parts.
As a time saver we suggest that you hook up the unit to your car with it not in the tank.  With the ignition on, have one person cycle the sending unit up and then down while another person watches the gauge in the car.  The sending unit has tangs that can be bent up or down to give the best full and empty reading on the gauge (you can also bend the float arm).  Usually the stock position is the correct one, but again this is a great time saver, as opposed to pulling the fuel tank back out to readjust.
Thank you!!
Frank’s Pontiac Parts is a fully licensed classic Pontiac dismantling yard located in the heart of the Mojave Desert in Southern California
CALIFORNIA RESIDENTS MUST PAY SALES TAX
Check out our eBay store for other items listed"
https://www.frankspontiacparts.com/
thanks for the info
I have just email Franks ....hopefully they can send along a dual line fuel sending unit....there is no place else I know of....tough find !!!
Let us know what they tell you. Hopefully they have what you need.
