STUMPED !!!
I have a 2009 Pontiac Vibe - 2.4l - 5 speed manual. the shift cable broke and GM is not making the OEM part in big enough numbers for demand. Is there another cable that will fit and function ??
The Vibe is essentially a Toyota Matrix. With that said, I am unsure if this particular part was swapped out. Might be worth a shot looking for a Toyota part. Otherwise, might want to check your local junk yards to see if there are any there.
Look at you Ringo....Good advice!  Here is another.   Oreilly auto parts, should be local where ever you are.
https://www.oreillyauto.com/shop/b/engine-parts---mounts-16774/transmission---transaxle-16780/transmission-parts-16520/at-shift-cable-12754/b6474b017f91?q=at+shift+cable
