1966 GTO Parts For Sale
After building a full restomod, I have many unused parts for sale that range from OEM used to new in box aftermarket. I've been buying and selling parts for over 40 years so I'm not looking to waste your time or mine. If you're interested in something, please email me at "mtrunz@yahoo.com" with your name and "GTO Parts" in the subject line. This makes it possible for me to track and respond to requests. If any pics are missing below, I'll email whatever you need upon request. I would consider selling everything lock stock and barrel to one buyer for the right price. The list is long but here it is:
Pontiac 1966 421 XYH 4 bolt main block punched out approximately .030 to fit stock 428 pistons. Ram Air IV cam, Ram Air III heads and 1967 HO aftermarket stock cast headers. Block was hot tanked, and magged before engine and heads were professionally built. I have the parts to complete the top end assembly (valley pan, gaskets, billet distributor, coil, wires and gaskets including thicker RA IV valve cover gaskets) but haven't had the time to finish it. If I complete it, I’ll sell it for $10,000 but I'd let it go for $8,000 as it sits with all of the parts to finish it. I'll include the 4-barrel intake and carb that came off of a 1970 RA III GTO if still available but no price reduction if they are sold.
1970 RA III intake and Quadrajet carb - $300.00 for both.
Complete and fully restored 1966 GTO Tri Power assembly with rebuilt carbs, new air cleaners and orig. chrome covers. Zero Miles $4,000.00
1966 389 "Big Car" (YF code) Nice bare block with bare 093 heads and Armasteel crank - $750.00
1966 4 speed Muncie transmission - 63,000 original miles. Inspected by Marshall Transmission before being stored. Includes new, never run center force clutch, pressure plate and throw out bearing. $1,850.00 for all
2nd 1968-70 Muncie 4 speed transmission P/M 3925660 - Pulled from running 66 GTO but never driven by me or inspected by a professional $500.00
OEM used HURST 4 speed shifter w/chromed HURST arm. Feels smooth and tight $500.00
Lakewood steel bell housing and scatter shield $750.00
OEM used Pontiac Rally 1 bare steel wheels - I have 5 and would like to sell them all together.  They all are in need of blasting and fresh paint or powder coating. $300.00 for all 5 which amounts to 60.00 each.
NOS GM Rally 1 wheel trim rings P/N 475019 (Complete set of 4 new in box). I’m told these are most likely service replacements because the mounting clips differ from the original 66 rings. $475.00 for the set of 4.
Heater box assembly (OEM VG to Exc condition) with brand new blower motor & heater core $400.00
Heater box assembly, OEM Used original condition - $150.00
Non AC 66 radiator core support  used $200.00
Aftermarket HD Radiator (Desert Cooler?) – for non AC manual transmission car - New in box $450.00
Aftermarket non AC fan shroud $120.00
Aftermarket Gas Tank - New in box $175.00
1966 GTO 10 Bolt 4.33 rear end OEM with drums, control arms with poly graphite bushings $1,500.00
1966 GTO 10 bolt posi 3.55 rear end  $800.00
After Market Heavy Duty Axles that can be used for either rear end - New in box $300.00
Stock Front drum and spindle assembly/pair $100.00
OEM Front upper & lower control arms with polygraphite bushings and new ball joints $750.00
Front and rear coil springs and KONI Shocks $200.00
New Boxed Rear lower control arms with poly graphite bushings $200.00
1966 GTO Non Tilt steering column that I purchased as restored w/firewall gasket - Never used $400.00
1966 GTO non tilt steering column pulled from parts car years ago $150.00
1966 GTO steering wheel horn bar and center very nice $175.00
1966 Dash housings - 3 Non AC cores unrestored without gauges $250.00.  / One with gauges $375
1966 AC Dash with gauges and rally clock. Unrestored condition  $525.00
1966 GTO 4 speed console complete $800.00
Several 64-66 GTO 4 speed console bases - $120.00 each
OEM Pontiac Vacuum Gauge - $275.00
OEM Trunk reel light $150.00
66 GTO/ LeMans  glove box doors, OEM used (2) - $75.00 each
OEM Delco Power brake booster New In Box $150.00
Rear sway bar - aftermarket for 1964-67 GM A Body $150.00
Several 4 way flasher assemblies from $100.00 - $300.00
1966 GTO Dash pads - one usable (driver quality) and one as core for restoration $250.00 / $150.00
1966 GTO Steering wheel cores (restorable) and horn bar $300.00 best wheel and bar / $100.00 core
1966 GTO Am OEM used Radio.  Not tested, as is $100.00
Die Cut Floor insulation still in box - aftermarket kit $75.00
Stock 389 exhaust manifolds $150.00/pair
Used starters (4) $50.00 each
Brand New, Steel (aftermarket) Alternator strap for 65-66 GTO Tri Power car W/Power Steering $20.00
1966 OEM used Pontiac Power Steering pump & pulley (pulled from my 63K Mile 66 GTO) $75.00
1966 OEM used Pontiac 4 speed Z Bar (pulled from my 63K Mile 66 GTO- short end broken) $50.00
1966 OEM used Pontiac 4 speed clutch fork (pulled from my 63K Mile 66 GTO) $75.00
1966 OEM used Pontiac 4 speed Bell Housing (pulled from 66 GTO parts cars) (2) $150.00 each
Bell housing, fork and Z Bar combo $275 for all
OEM used Rally gauge set - Speedometer & tachometer cleaned & calibrated, Gas/Battery, Water Temp/Oil $450.00
66 GTO Interior heater control panel assembly $200.00 Nice
66 GTO Interior heater control panel assembly $275.00 Nicer
Set of 4 vintage Crager mags on old tires, as is with tires. Will get tire sizes upon request. $100.00
IMG_2730.JPGIMG_2731.JPGIMG_2684.jpegIMG_2686.jpegIMG_3784.JPGIMG_3780.JPGIMG_2707.JPGIMG_2706.JPG
IMG_3665.JPGIMG_3672.JPGIMG_3663.JPGIMG_3395.JPGIMG_3396.JPGIMG_3398.JPGIMG_3394.JPGIMG_3420.JPGIMG_3401.JPGIMG_3415.JPGIMG_3427.JPGIMG_3436.JPGIMG_3454.JPGIMG_3450.JPGIMG_3441.JPGIMG_3462.JPGIMG_3434.JPGIMG_3463.JPGIMG_3464.JPG IMG_3461.JPGIMG_3457.JPGIMG_3458.JPGIMG_3460.JPGIMG_3471.JPGIMG_3473.JPGIMG_3477.JPGIMG_3478.JPGIMG_3479.JPGIMG_3481.JPGIMG_3476.JPGIMG_3495.JPGIMG_3496.JPGIMG_3497.JPGIMG_3498.JPGIMG_3597.JPGIMG_3604.JPGIMG_3377.JPGIMG_3381.JPGIMG_3482.JPGIMG_3484.JPGIMG_3491.JPGIMG_3490.JPG
Edited by mtrunz
So this is where all the good stuff went.
It's been a lifelong pursuit. Lot's of good stuff that needs a home.
