Transmission info/advice?
Growing up in Oz, the old jokes were:
Found On Rubbish Dumps (FORD)
and 'Just Holden together.'
Both were apt.
  • Replies 31
  • Views 2k
  • TWO LANE BLACK TOP
    TWO LANE BLACK TOP
    More Useless Trivia..??? Just in case anyone is curious...The transmission ID plate indicates.. Hydramatic..(different from the Roto-Hydramatic...Commonly Known as "slim jim") P = Stand
  • 64 kiwi boni
    64 kiwi boni
    Paul  I am with justA here  your block doesn’t have the metal to drill to mount a starter too. Your starter is mounted to the trans .  soo… any trans swap will require a adaptor kit for st
    TWO LANE BLACK TOP
    Bonne61... This is Probably a stupid question...But I'm going to ask Anyway...Have you checked the Transmission Fluid Level..?? With the car in Park with the Engine running and warmed up to
First On Race Day...Babe..
Don't Get me Wrong I'm a Hardcore GM Guy...But we have had our Asses kicked More than Once By Fords/Mopars...Through the years...On the Racetrack...So I have to give Credit where Credit is do...
AS far as Transmission Fluid goes...I Know from personal Experience That putting Type F/Mercon...B&M Trick Shift...ETC..Trans Fluid...In a GM Automatic Transmission...Will Drastically/Quickly Reduce the Life span of the Transmission..From Years to Monthes...Especially if the car is Driven hard...
The Same thing goes for installing a B&M Shift kit..Without going into a lot of Detail...Basically what the kit does is Reroute the way the trans fluid flows Through the Valve body and Increases the the internal Line Pressures...And generates a lot of Excessive heat to the point to where you have to use an External Trans Cooler...That is what makes them shift so Hard...Which is Good for Certain Racing Applications...But Not so much for Regular Street use...Unless you consider Automatic Transmissions...Differentials/U-Joints..etc.. As Sacrificial/Disposable parts...
Justa my 2 cents..
TLBT..
On 11/3/2024 at 5:26 PM, Bonne61 said:
Thank you.
Did you miss the Fatsco link has a tech line for answering transmission questions?  I didn't dive into the info, Justa passed it along as we didn't have all the info.  Back to my original question, where is your starter located?  Trans or block?
Edited by JUSTA6
Transmission, unfortunately...
I'll get in touch with Fatsco, thanks
Justa my 2 cents..
TLBT..
Absolutely not...at the age of the car there are enough sacrificial/disposable parts as it is, that weren't initially designed to be so😆
I figured that to be the case, but thank you for sharing 😃
Justa my 2 cents..
TLBT..
For Old Retired Dudes!!!!!   We need something dependable to go get our Pontiac parts.:driving:
Well, I AM still a Ford truck guy, always have been. That said my two favorites have always been "F@*ked Over Rebuilt Dodge" and "Flip Over Read Directions" :rofl:
Found On the Road Dead is another classic.
