Help Me PLEASE!
I have I have a 1998 Pontiac Firebird V6 the fuel pump is inside the fuel tank I swapped it out but I don’t know how to reconnect all of the hoses can someone help me pleasea 1998 Pontiac Firebird V6 the fuel pump is inside the fuel tank I swapped it out but I don’t know how to reconnect all of the hoses can someone help me please
Solved by 64 kiwi boni
hi Julien, this youtube video may help you mate
looks like apita job !
  • Solution
The other thing you could do is find another bird and note how the hoses lay, if your is the same as the video
I see 2 hoses are bigger so that halves the guess work
see if you can get all four hoses to lay naturally parallel to each other , this may give u a clue
also note if the connectors are the same
you may find all four are different (that maybe wishful thinking)
worst case , you have to trace each hose to we’re it goes
first clue , one of the bigger pipes off the pump will be the flow line to the fuel rail
one of the smaller pipes will be the return line from the pressure regulator and I expect at least one of the pipes is a vent line
