1976 Grand Prix $1800
Just testing the waters out. I have another Pontiac to get home, and need to clear out some space, and recoup some of the $$$ I have spent. 400 - TH400 with 3.08 rear. Runs, shifts, stops great. 1 finger steering. Rebuilt the carb (twice actually), rebuilt the distributor from top to bottom (pickup coil, coil, module, MSD advance, cap, rotor, wires) new fuel pump and lines. Cleaned out the fuel tank and installed new inline filter. Found the correct breather to valve cover connection, new oil and ZDDP, upper rad hose, heater hoses, and vac lines. Received the car with the wrong sunroof in it, so I had another '76 roof skin stitched over it and sealed until the original factory unit could be installed. Found all the interior panels and re dyed them including the trim pieces. Rear panels are in, along with the upper back seat. Installed new drivers door striker and adjusted it. I have 2 consoles and a floor shifter (correct to SJ) and much more that goes with the car. More pictures on my profile. Thanks.
Edited by steveeoaktree
Adding pictures
