ok now what! still hard to sart
i posted a while ago, spins over when i stop it spinning it starts but not while spinning over. was told its the ign switch on the steering column ,i just replaced it and still doing the same thing, its got a pertronic ign instead of points , was fine until recently scratching my head ,any ideas? does it hot or cold.
Assuming the problem is in the steering column for a moment….
Have you checked the metal rod that goes from the key switch to the ignition switch is straight and true, and not bent?
Have you validated the neutral safety switch is good?
Check you positive cable and make sure it is not coming in contact with your block or exhaust. I had this happen once. It melted the insulation off the wire and grounded out thru the block.
I had a wire short between the neutral safety switch and the fuse block that cause the car to no start.
thanks i got something to look for now. i'll let you know how i do
