Non Pontiac Retirement Gift to Myself, 1971 Fiat 130 Coupe
Christmas in February! Congrats Jeff!
  • Replies 31
  • Views 1k
  • The Fiat 130 is an iconic classic design - you have done well. It will break down and leave you sobbing at the side of the road but think how cool you'll look next to it whilst waiting for a tow. Are
  • Jeff congrats on getting one of your dream cars. I know next to nothing about import cars. What I know is: Avoid anything built by British Leyland period! BMW is for sports car fans, Mercedes for Eur
  • cammerjeff
    cammerjeff
    Just received some pictures of the car prior to it being loaded on the Trailer in Baltimore, it looks like it has survived the trip so far. Due to be delivered tomorrow about noon EST.
Well the Title paperwork finally arrived today, only a month after the car, the luggage and some parts I ordered from Europe, including 15 square meters of Orange Velour material to redo the front seats and door panels later this year.
The material is from the original manufacturer of the material for the car, they are still in business and apparently ran a batch of the Orange and Blue Velour in 2024, they sold out of the Blue, but still had some of the Orange in stock. So I figured I better buy it while it is available.
So I have been busy replacing the fluids as I have no idea when the last time they were changed. So far I have changed the Engine Oil & filter, rear axle oil, and the brake fluid. I had an issue with the rear brakes locking up when I was pushing the old fluid thru using a one man brake bleeder (check valve). After about 5 pumps of the brake pedal the pedal and rear brakes locked up. After doing some research I found out the car has an early rear disc mechanical anti-lock system. It uses a shut off valve to cut off the fluid flow to the rear disc's when the rear suspension is unloaded. To prevent the rear brakes from locking up in panic stops, similar to the system used on 1990's pickup trucks. But the system uses linkage connected to torque arms thru linkage attached to the top of the lower control arms.
I had inadvertently simulated the conditions to shut off the pressure to the rear brakes, with the car jacked up and the rear suspension hanging full down. Also the brakes are plumbed differently than what I am used to. The front disc's use 2 piston calipers, and one piston on each side is plumbed to each side of the master cylinder. The rears are plumbed to the rear side of the master cylinder like I am used to.
Also I like that every fluid system has a drain plug (except the brakes of course) even the fuel tank. So it is easy to drain the rear axle, transmission, and cooling system. The cooling system has the normal radiator drain valve, but also has a drain plug in the lower radiator hose mounting outlet, and each side of the engine block.
I have also replaced the driver side power window motor, and the coolant temp sensor. So progress.
Edited by cammerjeff
….and you are enjoying every minute of it! I think it’s cool that you have the exact interior material. Good for you Jeff!
  • 3 weeks later...
Well I knew it would not be a one trip transaction at the Michigan Secretary of State to Title and Plate the Fiat. Went today and after proving the car was 25+ years old, so it does not need the original embossed EPA and customs clearance forms.
I have to have the original Title and Bill of sale, translated from French to English, that's $300 I didn't expect to have spend. Plus the car needs to be inspected for all safety equipment to be working.
And now the passenger side window motor quit working, angry. But I should have the paperwork translated tomorrow, and I have the needed inspection form. So maybe by the end of this week it will be legal to drive!. The clerk at the SOS said it is 50/50 that they will require the Speedo to be swapped out from a KPH to MPH unit. I sure hope not!
How easy would it be to get a new MPH speedometer for this car? I doubt there is a lot of them sitting on a shelf somewhere nearby. The safety inspection is expected, the translation of the title was a definite curveball though.
They did sell both the 4-Doors and Coupes in England, and the cluster is the same for the both from 71-77, so they do exist? But the odds of finding the one available for sale in the UK is pretty Slim. The ones sold in Australia would be in KPH I think.
I hope they don't insist on it being changed out, as the one I bid on BAT several years ago had a KPH cluster and was plated in IL. so titling it would not have been an issue.
  • 3 months later...
Well Today the car is now officially street legal! After 3 trips to the Secretary of state, the 1st time they told me I had to have the French Title and auction house paperwork translated by a recognised translation service from French into English. OK no Problem I get that.
The second trip they told me the car had to be inspected by the State Police, I contacted the State Police and they said they don't do that anymore, angry so SOS waived the Safety inspection.
Today 3 hours, mostly caused by having to explain the translation of the original documents to the counter person, several calls to the State Capital in Lansing, waiting for someone in Lansing's IT department to add a 1971 Fiat 130 Coupe to the drop down list of eligible vehicals that could be registed. A quick inspection of the odd Vehical Number Plate to confirm it matched the paperwork. And I have a Temp Registation and Plate! And supposedly the Historical Plate will show up in about a week.
Whew!
Now the bad news, I had to prop up the passenger side window today with a couple peices of wood. A pulley for the cable operator window regulator broke when I went to raise the window on wendsday, and as the regulator was moving at the time the pulley broke I now have a rats nest on the regulator. I found a Salvage yard that has a Fiat 124 in it, and I pulled all the window regulator pulleys out of it. They seem to be the same so now I have spares.
But I have no Idea how ro rewind the cable onto the regulator. After trying several times I resorted to propping up the window for now. Every one says it not worth messing with, and buy a new one. Problem is I do not know if the available ones designed for Fiat 124's and X1/9's is the same?
So it looks like the wife will have to suffer with a closed window on the 6-8 hour drive to Getteysburg PA for the Fiat Freakout on Tuesday.
