NEED HELP WITH CLUSTER
Idk wut happend but my instrument cluster doesnt work
Hi GRNieyeDEMON - let's be clear. Are the gages not working or the just the lights?
My first guess would be a blown fuse or a bad ground. Worst case scenario would be a damaged instrument cluster.
What have you done thus far?
Well i checked out all the fuses there good i even took off the instrument cluster cleaned it off looking for any breaks in the circuit and there was nun so im gonna check otha fuses
I assume you've checked both the side dash fuse panel on the driver's side as well as under the hood. Does your car have a passenger side fuse panel as well? I know the '98 GP had them, but I am less certain about the GA.
When you removed the cluster, did you notice any corrasion or melted or distorted connections? Have you installed an aftermarket radio?
Yes there is an aftermarket radio and no just the one on driver side and under da hood i just got a volt meter wut am i looking for to make this work again?
