front turn lense glue removal
just got a new lense in for the front turn signal, must of been siliconed on at factory to seal it had to fight to get it off. what can I use to remove the silicone from the bulb housing? have it sitting in some gas and its working some, is there something that will work better and faster that you know of?
Pictures? I'd use a hook shaped pick tool to loosen the sealant by hand. Gasoline? Might be too harsh for the shiny finish such that it might not be shiny again.
And the gasoline vapors are a little to explosive for me to use it like this.
yup got it done I got lense off and just let it sit in little gas ,I remember years ago a guy put some silicone on carb bowl on bike to stop leaks and gas ate it he ended up pulling out the jets and cleaning them out after they got clogged .all set thanks!
