have always run the vent to the ground inside of the air cleaner on my bikes, looking at catch cans and thinking that connect it to PVC so it just goes through the can which should collect oil to dump out later. the cans I see have a breather filter which I believe the pvc will draw through that inside of from the motor so was going to plug breather off, or should I let it do that as to not draw from motor? so what is your thinking on which way I should go, thanks!
