driveshaft removal
need a u-joint been a long time since I pulled a driveshaft ,70 lemans automatic when I pull it will the trans leak fluid? I'm putting a pan under just in case.
A small leak unless the bushing in the tailshaft cover is heavily worn or the seal is worn.
ok thanks it's been a long time since I had to pull a driveshaft couldn't remember what to expect lol
