ALUMINUM DESERT COOLER RADIATOR
Part# P119AKA
Description1967 ALUMINUM DESERT COOLER RADIATOR, AT 15 1/2". PLEASE CLICK ON DETAILS. (RP)
Net Comments66 APPLICATIONS WILL NEED TO USE P119ATF ADAPTERS FOR TRANSMISSION LINES AT RADIATOR. IF CAR IS FACTORY EQUIPPED WITH A 4 CORE RADIATOR, THIS BOLTS IN WITH NO MODIFICATIONS. FOR 1964-67 CARS THAT WERE ORIGINALLY A 3 CORE WE HAVE THE P120 CONVERSION KIT AVAILABLE. THE HEIGHT OF YOUR RADIATOR IS FOUND BY MEASURING VERTICALLY BETWEEN THE TANKS. FOR 1964-1967 RADIATORS THIS SHOULD 15 1/2" OR 17 1/2". AT TIMES CUSTOMERS CANNOT IDENTIFY THEIR PROPER APPLICATION. THE CORE SUPPORT CAN BE USED FOR THIS PROCESS. SEE HARRYS TECH TIP IN GTO RADIATOR SECTION OF CATALOG. A 17 1/2" RADIATOR CANNOT BE USED IN A CAR ORIGINALLY EQUIPPED WITH A 15 1/2" OR VICE-VERSa
https://secure.amesperf.com/qilan/Search_Web?order_number_e=NTMzNjI2OQ%3D%3D &method_1=Y&method_2=&on=Y&search_method=1&search_part_num=p119aka
I am selling this for my dad.  He had a 1966 GTO that he bought this for and never used it.
Still New in Box From Ames Performance.
Asking $400
Edited by plfd90
