1986 Pontiac Fiero SE
1986 SE 2.8/4-spd with 166000 on car, complete exhaust, suspension, and brake replacement/upgrade with quality parts in 2004. Added Ocelot exhaust from Fiero Store along with thicker front sway bar and added rear sway bar with Koni shocks and struts... Car handles like it's on rails. Spun rod bearing in 2006 and swapped in 2.8 from My 1985 Fiero SE automatic/all power parts car that simply needed brake system replaced. 1985 motor has 127000 on it and I ported,polished, and gasket matched the heads Myself and put in new valve lifters,push rods, hand lapped valves and added 'roller rocker' rocker arms.changing compression ratio boosting hp. Haven't driven it since upper motor work done.... ran motor long enough to break in new parts but never on road.....currently needs clutch work to get back on road.
- Color: Red
- Price: 1100
- Year: 1986
- Odometer: 127000
- Odometer Unit: Miles
- Description: 1986 SE 2.8/4-spd with 166000 on car, complete exhaust, suspension, and brake replacement/upgrade with quality parts in 2004. Added Ocelot exhaust from Fiero Store along with thicker front sway bar and added rear sway bar with Koni shocks and struts... Car handles like it's on rails. Spun rod bearing in 2006 and swapped in 2.8 from My 1985 Fiero SE automatic/all power parts car that simply needed brake system replaced. 1985 motor has 127000 on it and I ported,polished, and gasket matched the heads Myself and put in new valve lifters,push rods, hand lapped valves and added 'roller rocker' rocker arms.changing compression ratio boosting hp. Haven't driven it since upper motor work done.... ran motor long enough to break in new parts but never on road.....currently needs clutch work to get back on road.
- Make: Pontiac
- Model: Fiero SE
