Hello from AZ
My name is Mike and i have owned and have been building Pontiacs for the past 40 years. Here is my 1968 Firebird at the BOP car show a few years ago. i purchased it in 2005 after moving to AZ. I completely took the entire car apart and stripped it to bare metal, did the bodywork and paint and built the entire car. I built a few different engines for the car over the years. Currently has a 400 with a 75mm turbo and holley EFI.
welcomeFP
That is one nice bird! Love to see a build topic of your work
Here is an engine picture
Thanks for sharing. I am curious to know what plenum and throttle body you bolted to the intake manifold. I have yet to see this EFI setup on a Pontiac.
Its just a Holley elbow with a 108mm throttle body that bolts to any square flange intake manifold
that is sooo cool !!!
i see you have injectors in the manifold , did you build that yourself ?
i would be super keen to build a direct port injection on the 486 ci stroker i am building for my 68 ! and build my own stand alone ecu to run it and the timing
There are a few intake manifolds that are made with injector holes.
Why build a ECU when there's plenty good ones out there?
i didnt know that there was pontiac manifolds avaible with injector holes!!!
Ah ! i kinda like building my own systems and i can custom them to the build, but yes ! there are plenty of plug play units , but down under, i stuggle to fine tuners who can tune them !
so i used either factory ecus and have them customised or favour megasquirt and link brands justA so i get that suport when somethings not right cheers
I have ran the Megasquirt ultimate ECU before and will be using it on another one of my cars.
i had never used them until i built my mark 1 cortina and used one with the support of the nz agent and its worked soooo well on the little car and the engine i put in it !!!
Mike, tell me more about your motor !
1969 400 block, factory crank, #16 D port heads with Incolnel valves, 24cc dished ross pistons, callies rods, custom solid flat tappet.
Kiwi - Edelbrock makes a couple of direct port injection intake manifolds for Pontiacs.
thanks frosty, it give me a idea for the stroker motor !!!
