1967 Pontiac GTO
This 1967 Pontiac GTO has undergone a meticulous Frame-Off, Rotisserie Restoration that took a little over two years to complete! It has a straight body, glossy Burgundy Paint finish, Parchment Interior, Dual Headlights, Hood Scoop, New 15'' Chrome Cragar S/S Wheels, New BFGoodrich Radial T/A Tires, Chrome Bumpers, and polished trim all around. Under the hood sits a Pontiac 455ci High Output V8 Engine with a Holley 4-Barrel Carburetor sitting on top! An Aluminum Radiator that's paired with an Electric Cooling Fan keeps things cool. Power is sent to the rear tires through a Tremec TKO500 5-Speed Manual Transmission and a 12 Bolt Rear End with 3.07:1 Gears and Posi-traction! This Pontiac is equipped with AC and power front disc brakes.
The interior sports Front Bucket Seating with Lap Belts, Rear Bench Seating, Parchment Vinyl Upholstery throughout, Black Carpeting, Wood Trim, 3-Spoke Wood and Stainless Steering Wheel, Stock Dashboard Gauges with Aftermarket Auxiliary Gauges nearby, Retro Style Aftermarket Radio, Vintage Air Control Panel, Center Console, Floor Shifter, and original style Pontiac Rubber Floor Mats. The underside sports a well conditioned Frame, Floor Boards, Pinch Welds, Rocker Panels, New Fuel Tank, New Fuel and Brake Lines, Brakes all around, Complete Drivetrain, Steering Components, Front Sway Bar, Independent Front Suspension, 4-Link Rear Suspension with Reinforced Arms, along with the Dual Exhaust System that's fitted with Flowmaster Mufflers!
- Color: Burgundy
- Price: --
- Year: 1967
- Odometer: 4200
- Odometer Unit: Miles
Description:
The interior sports Front Bucket Seating with Lap Belts, Rear Bench Seating, Parchment Vinyl Upholstery throughout, Black Carpeting, Wood Trim, 3-Spoke Wood and Stainless Steering Wheel, Stock Dashboard Gauges with Aftermarket Auxiliary Gauges nearby, Retro Style Aftermarket Radio, Vintage Air Control Panel, Center Console, Floor Shifter, and original style Pontiac Rubber Floor Mats. The underside sports a well conditioned Frame, Floor Boards, Pinch Welds, Rocker Panels, New Fuel Tank, New Fuel and Brake Lines, Brakes all around, Complete Drivetrain, Steering Components, Front Sway Bar, Independent Front Suspension, 4-Link Rear Suspension with Reinforced Arms, along with the Dual Exhaust System that's fitted with Flowmaster Mufflers! - Make: Pontiac
- Model: GTO
