1964 Pontiac Grand Prix
Needs full restoration. Hard to find some parts. I am currently in the process of partial frame of restoration. This is going to be a restomod while still using original or remanufactured parts where applicable. I'm quite mechanically inclined, been a mechanic since I was 15 so plan to do most of the mechanical and electrical work. The engine will go to a engine machine shop for a full rebuild with some slight modifications done. I plan to put a hig h performance cam and lifters, double roller timing chain, polished and ported heads and balance and blueprint the block.
  • Color: Ermine White
  • Price: 5000
  • Year: 1964
  • Odometer: --
  • Odometer Unit: --
  • Description: Needs full restoration. Hard to find some parts. I am currently in the process of partial frame of restoration. This is going to be a restomod while still using original or remanufactured parts where applicable. I'm quite mechanically inclined, been a mechanic since I was 15 so plan to do most of the mechanical and electrical work. The engine will go to a engine machine shop for a full rebuild with some slight modifications done. I plan to put a hig h performance cam and lifters, double roller timing chain, polished and ported heads and balance and blueprint the block.
  • Model: Grand Prix
