1968 Pontiac Lemans
1968 Pontiac LeMans Convertible VIN 237678P116599 Craigslist https://madison.craigslist.org/cto/d/1968-pontiac-lemans/6308497115.html Facebook pg. https://m.facebook.com/68LemansConvertible4SaleInWisconsin/ http://facebook.com/68LemansConvertible4SaleInWisconsin/ Videos - Putting away winter 2016 https://youtu.be/iJoUkxjf0sU - Sound of exhaust with motor running https://youtu.be/e2GOhC3yUbA - Walk around outside https://youtu.be/MDgUCoTnFT0 - Motor running https://youtu.be/Q3K4witlklQ - Cruising the backroads https://youtu.be/70NNq4SvmHE Details -Red exterior -black interior - modern leather front seats, original vinyl rear seat -black power top with glass rear window -159k on the body -Solid frame and floorboards -500 miles on professionally rebuilt period correct non-numbers matching motor, 400, 4 bbl 625 cfm Carter AFB -MSD electronic ignition -Non-numbers matching Turbo 400 automatic with floor shifter (converted from a column shifter) -Hedman Headers -Rebuilt power drum brakes -Power steering -Console -Modern leather front bucket seats -Rear vinyl seat in near perfect condition -Body work done 20 years ago -Used front fenders from down south, rust free -Trunk floor replaced -Rocker panels replaced -New rear quarters -Rear bumper re-chromed, -Front bumper de-chromed and painted body color -69 GTO hood -Aftermarket rear wing -Front suspension rebuilt -All new shocks, springs, and bushings (front and rear), -New engine wiring harness -Tires BF Goodrich 235/60/14 on late 60s/early 70s Oldsmobile rims -Motor details: -Cylinder heads completely rebuilt -Block bored 0.40 over -Crank smoothed -Upgraded cam -Professionally cleaned and painted Issues/Needs -8" scratch in clear coat on passenger front fender -Lower rear corner of passenger door starting to bubble -Dent in front valance, driver side -Chrome on passenger front quarter window has mild pitting -Weatherstripping for both front quarter windows needs to be replaced -Chrome strip with weatherstripping on passenger side rear window needs to be replaced -top of the Rear seat has a 4 inch section of a seam that needs to be re-stitched -Dash needs to be recovered -Steering column -Shift indicator needs to be ground down -Shift indicator location on steering column needs a piece of metal 2 be welded in to seal up the hole where it used 2 be -Clock doesn't work -speedometer works yet does not read correctly over 30 mph. The faster you go the more it is off -Reverse lights, interior lights, & top operate off manual switches under the dash -Small transmission fluid leak -Radio works sporadically 8,820 of these made, less than 4000 of them survived. Own a piece of history and have some fun. $19500 or Trade Greg 608.698.8733
  • Color: Red
  • Price: 19500
  • Year: 1968
  • Odometer: 154000
  • Odometer Unit: --
  • Description: 1968 Pontiac LeMans Convertible
    VIN 237678P116599
    Craigslist
    Facebook pg.
    Videos
    Details
    -Red exterior
    -159k on the body
    -Hedman Headers
    -Power steering
    -Console
    -New rear quarters
    -69 GTO hood
    -Motor details:
    -Crank smoothed
    -Upgraded cam
    Issues/Needs
    -Steering column
    -Clock doesn't work
    $19500 or Trade
    Greg 608.698.8733
  • Model: Lemans
