Welcome!
Welcome to Forever Pontiac, where we keep the memory of Pontiac alive with great discussion, maintenance tips, restoration/modification progression "blogs" and help from professional & DIY mechanics. Also, wonderful competitions that occur regularly. Please register for an absolutely free account to join in!
By MAX-2.8 4 spd muncie Fiero,
04/09/2016
- 777 views
- Pontiac This Or That Score: 313
- Pontiac This Or That Place: 305
out of 1317
- Make Pontiac
- Model Fiero SE
- Color Red
- Price 1100
- Year 1986
- Odometer 127000
- Odometer Unit Miles
- Description 1986 SE 2.8/4-spd with 166000 on car, complete exhaust, suspension, and brake replacement/upgrade with quality parts in 2004. Added Ocelot exhaust from Fiero Store along with thicker front sway bar and added rear sway bar with Koni shocks and struts... Car handles like it's on rails. Spun rod bearing in 2006 and swapped in 2.8 from My 1985 Fiero SE automatic/all power parts car that simply needed brake system replaced. 1985 motor has 127000 on it and I ported,polished, and gasket matched the heads Myself and put in new valve lifters,push rods, hand lapped valves and added 'roller rocker' rocker arms.changing compression ratio boosting hp. Haven't driven it since upper motor work done.... ran motor long enough to break in new parts but never on road.....currently needs clutch work to get back on road.
