1964 Pontiac Tempest two-door post coupe. 3400 lbs. Original Headliner, 107k miles, purchased on 04-02-05 1973 YC 455 with 1977 6X-8 400 Trans-Am heads, approx. 9.5:1 compression, Accel HEI Ignition, Edelbrock Performer RPM intake with an Edelbrock Thunder Series 800 CFM carb. Holley electric fuel pump, Factory chrome valve covers, Ram Air Factory headers. Transmission is a turbo 350, B&M Quicksilver shifter and the rear is a 10 Bolt limited slip with 3.55 gears. Centerline wheels and tires. The rears are 15x8.5 with a 235/60-15 tire. The fronts are 15x3.5 with a 165/15 tire.
  • Color: Blue
  • Price: 0.00
  • Year: 1964
  • Odometer: 107999
  • Description: 1964 Pontiac Tempest two-door post coupe. 3400 lbs. Original Headliner, 107k miles, purchased on 04-02-05 1973 YC 455 with 1977 6X-8 400 Trans-Am heads, approx. 9.5:1 compression, Accel HEI Ignition, Edelbrock Performer RPM intake with an Edelbrock Thunder Series 800 CFM carb. Holley electric fuel pump, Factory chrome valve covers, Ram Air Factory headers. Transmission is a turbo 350, B&M Quicksilver shifter and the rear is a 10 Bolt limited slip with 3.55 gears. Centerline wheels and tires. The rears are 15x8.5 with a 235/60-15 tire. The fronts are 15x3.5 with a 165/15 tire.
  • Make: --
  • Model: --
