1975 Pontiac Formula
Stock 400 and TH 350 trans and open 2:56 rear end. 5C heads plugged with smog devices removed. Stock valve train with Isky polylocks. Rochester blueprinted for Summit 2801 cam with Edelbrock dual roller. Functioning hood scoops with Formula air cleaner. Headman 3 tube headers, 2.5 inch pipes into Dual Hush Thrush mufflers out the back. Urethane bushings where it doesn’t move and rubber where it does. 10:1 steering gear and Cold case Radiator with stock clutch fan and shroud. Runs on 87 and cool on triple digit summer days. Still debating A/C and rear gear change.
- Color: Silver
- Price: 1
- Year: 1975
- Odometer: 50985
- Odometer Unit: Miles
- Description: Stock 400 and TH 350 trans and open 2:56 rear end. 5C heads plugged with smog devices removed. Stock valve train with Isky polylocks. Rochester blueprinted for Summit 2801 cam with Edelbrock dual roller. Functioning hood scoops with Formula air cleaner. Headman 3 tube headers, 2.5 inch pipes into Dual Hush Thrush mufflers out the back. Urethane bushings where it doesn’t move and rubber where it does. 10:1 steering gear and Cold case Radiator with stock clutch fan and shroud. Runs on 87 and cool on triple digit summer days. Still debating A/C and rear gear change.
- Make: Pontiac
- Model: Formula
