2009 PONTIAC G5
This is my 2009 Pontiac G5 base model. 2-door coupe 2.2L engine 155 HP 90K miles original Paid $4200.00 for the vehicle in 2017 with 75K miles. I bought this car in 2017 with 75K miles on it and have replaced and fixed all its problems or issues it had when I first got it. AND got all its interval services done as well that it was due for. I poured just over $4000 dollars of repairs into this car. Excluding maintenance. Thats why the price is 8 Grand because its worth that and drives brand new, it will take you across the country and back without an issue at all. A1 Certified Reliable and Dependable. Less than 30K miles driven currently in ownership, I have replaced all of the following: All the Struts & Springs suspension The steering column i-shaft New Brakes & Rotors 4 brand new tires New Throttle body New Headlights because water damage to old ones New Fog Lights Entire LED kit bulbs for the car Replaced the Battery Replaced the dome light with one with map light toggle buttons Replaced the buttons on the steering wheel (left) for cruise control and info, since they werent working properly. INSTALLED the right side steering wheel buttons from a flat silver plain plate, to full functioning buttons for radio and call accessory, just need bluetooth now Replaced the cracked windshield Replaced the radio as it was completely scratched up and destroyed on the buttons For Interval Mileage maintenance, I have done the following: Cabin Filter Replace Engine Air Filter Replace Full Synthetic Oil Changes every 3K miles Transmission Fluid Exchange Fuel Injector Induction Cleanout Brake Fluid Flush Coolant Flush What is still fine but will need changed in future: Serpentine belt.. (im watching you..) No cracks yet, still good. ZERO ISSUES, ZERO WARNING LIGHTS ON DASH. Nothing wrong with it. Drives like a Cloud and handles so dang good. <3
  • Color: TITANIUM METALLIC SILVER
  • Price: 8000
  • Year: 2009
  • Odometer: 90000
  • Description: This is my 2009 Pontiac G5 base model.
    2-door coupe
    2.2L engine 155 HP
    90K miles original
    New Brakes & Rotors
    4 brand new tires
    New Throttle body
    New Fog Lights
    Brake Fluid Flush
    Coolant Flush
  • Make: PONTIAC
  • Model: G5
